Go to Post Having the ability, opportunity, and inclination to do manual labor makes you a better engineer. - MrForbes [more]
Unread 01-13-2010, 06:55 PM
Thomas4019 Thomas4019 is offline
FRC #3006
Thomas4019 is an unknown quantity at this point
Java Camera Video on ClassMate
Has anyone gotten the Classmate to show the video stream while using Java as our programming language? If so any ideas on how get it working? I heard that merely calling AxisCamera.getInstance() will start the stream but this didn't work for us.
Unread 01-13-2010, 09:36 PM
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Re: Java Camera Video on ClassMate
You will need to start the Driver Station and the Dashboard I assume, on the Classmate. As the program that uses the Axis camera is running on the cRIO and you need something running on your desktop to display the video coming in.
Unread 01-14-2010, 09:54 PM
FRC #3006
Well, we have the driver station setup and I believe updated. It just keeps saying "timeout in camera communication". However, Java can internally see the camera and the sample Java vision recognition code is working.
Unread 01-15-2010, 01:44 AM
FRC #3006
The problem we are having is that the video is not showing up on the dashboard (classmate pc). We are now worried that the whole top half of the driver station program is not recieving any communication because it looks like it isn't updating the PWM or analog input values as well.
Unread 01-15-2010, 01:19 PM
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
We also seem to have this problem; nothing in the top portion of the dashboard seems to change. I'll try testing it again today, of course.
Unread 01-15-2010, 01:28 PM
Daniel Jones Daniel Jones is offline
AKA: Hanes
FRC #0190 (Gompei and the HERD)
Daniel Jones is on a distinguished road
The camera should start displaying the feed once getInstance has been called. The rest of the data on the dashboard needs to be sent manually, as seen in the dashboard example project in the NetBeans samples.
Make sure that you have the latest version of the driver station installed correctly, which may require uninstalling the driver station and reinstalling.
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
"there are 10 types of people in this world, those who understand binary and those who don't"
Unread 01-15-2010, 01:43 PM
FRC #3006
But how can we uninstall the dashboard. I couldn't find it in "Add or remove programs" nor in the DSUpdate1.0for2010 executable.
Unread 01-15-2010, 06:28 PM
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
We're having the same problem. We deployed the default code in LabVIEW, and then when we connect the robot to the ClassMate, we see "Timeout in Camera Communications" where the video feed should be displayed. Has anybody found a solution? (Our DS is version 2010.01.06.00.)
Unread 01-16-2010, 12:18 AM
Michael DiRamio Michael DiRamio is offline
FRC #1114 (Simbotics)
Michael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond repute
There seems to be an issue with the DS update only updating the "lower half" of the Driver Station (the actual driver station program) and not updating the "upper half" (the dashboard program).
To fix this, go in to your developer account, run the installer and select "remove this feature" on the "Features to Install" screen.
After it finishes, run the update again to reinstall the Driver Station/Dashboard.
Setting up your new Classmate for Java technology Techwiz Java 2 01-10-2010 11:46 PM
Camera Control in Java Imadapocalypse Java 1 01-09-2010 09:46 PM
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 08-31-2009 03:55 PM
Video: #1860 camera tracking sloteera Programming 2 02-01-2009 11:29 PM
Camera Video out Dr Nick Programming 9 02-15-2007 10:32 PM
