Go to Post You can make unfounded guesses, but chances are you'll come off looking like a moron. Let's try and avoid that. - Karthik [more]
Unread 13-01-2010, 19:25
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Question opposing alliance zone?
Is the opposing alliance zone considered the end with their two goals or is it half of that section where they start? Because if the entire section is their zone then that would mean that only one robot can be blocking goals and durning atonomous you would have to stay in your section. Which is right?
Unread 13-01-2010, 19:57
TomH's Avatar
TomH TomH is offline
FRC #0087
TomH has a spectacular aura aboutTomH has a spectacular aura aboutTomH has a spectacular aura about
Re: opposing alliance zone?
It is the entire side (both sides of the white line) that are considered the opposing alliance's side, and in autonomous you are not allowed to cross the white line completely (you can still go through the tunnels), although in tele-op you can, but you are only allowed to have one robot at any given time on your opposing alliance's zone, which is both side of the tape.
Unread 13-01-2010, 20:07
AKA: carroll
thanks so much TomH
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 13-01-2010, 21:51
GaryVoshol's Avatar
Cogito ergo arbitro
See the picture in section 6.2.1. "The FIELD includes two BUMPS that divide the FIELD into three regions (the RED ZONE, the MIDFIELD, and the BLUE ZONE)."
The BLUE ZONE is between the BLUE ALLIANCE WALL and the BLUE BUMP. Only 1 RED robot can be in this ZONE at any one time.
(since 2004)
Unread 13-01-2010, 22:07
hotapay42 hotapay42 is offline
FRC #2450
hotapay42 will become famous soon enough
ok, just clearing this up for myself and others:
you are trying to defend the goals to either side of you, and score at the far end, but only 1 robot from your alliance can be on the far side, correct?
thanks to whoever answers
Unread 13-01-2010, 22:11
AKA: carroll
well from what they are saying we score in our own goals. our alliance can only have one robot in the opposing alliances zone ( the section with their two goals) so if you are trying to block their goals there can only be one robot in that area. hopefully this helps
Unread 13-01-2010, 22:13
IBdrummer's Avatar
IBdrummer IBdrummer is offline
AKA: Beau Muniz
FRC #5492 (Winners Circle Robotics)
IBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of light
You score on the close side, your home zone, but only one robot can be at the far side which is their scoring zone. So only one of your alliance's robot can be on the farthest section defending.
Unread 13-01-2010, 22:19
FRC #2450
haha thank you so much, especially cuz i was dead wrong
<G29> Robots in opposing zones. gorrilla Rules/Strategy 25 10-01-2010 13:16
Is pinning opposing robots trailers allowed? spiffyspleen Rules/Strategy 22 05-01-2009 16:47
Best Alliance in the Alliance Era of FIRST Corey Balint General Forum 28 05-09-2006 20:14
null zone Xufer Programming 9 15-02-2004 12:54
Lifting opposing robots D. Gregory Rules/Strategy 2 07-01-2003 14:06
