Go to Post If there is water in the 2006 game, I will blame it on Gary. - dlavery [more]
Unread 13-01-2010, 19:05
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question small scale winch
Is there such a thing as a small-scale winch with a quick release? My team is thinking of using a winch to pull back on a cable, which would put tension on surgical tubing up above. We plan on having some sort of quick release so it will snap and produce more force. Are there any other teams using this type of idea?
Thanks,
Mitch Guzman
Team Captain
#1566 The Ammoknights
be prepared for the unexpected
Unread 13-01-2010, 21:00
Shawyan Shawyan is offline
FRC #1334
Shawyan is an unknown quantity at this point
Re: small scale winch
We are thinking about using that idea. One problem we have already encountered (and are having extreme difficulty fixing) is the rule that you can only leave the robot for 2 seconds to hit the ball and back. That is the 3" outside the frame perimeter and before the end of the bumper.
The reason for this being, if it does not leave the frame perimeter, there is NO way to get enough force to lift the ball (which is one of the main advantages for kicking).
Unread 13-01-2010, 22:11
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
I was actually thinking about this a couple days ago, but I abandoned the idea because of complications. I'll let you know what I came up with though.
I was thinking something akin to a cello tuning peg, where the cable would be fed through a little hole in the middle of a peg, and then the peg would be turned with a motor. When the peg is turned, the cable wraps around it and applies tension to whatever is attached to the other side.
And then I encountered the problem of the quick release. Depending on the amount of tension you will encounter, you'll have to decide on what motor to use. You'll probably need something that is geared for torque rather then speed, like a window motor. Unfortunately, window motors cannot unwind quickly enough to have a "quick" release. I started to think about using some sort of "cocking" mechanism to hold the peg in place until the actuation was needed, but I got lazy. Maybe you can figure something out? Just an idea
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 13-01-2010, 22:15
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Check out 1114's 2008 puncher. I'm pretty sure they used a dog gear to winch it in and a pneumatic punch out for the quick release function.
Unread 14-01-2010, 02:12
Says the team that used a motor to winch in their shooter AND release it, that same year...
There are pictures of that one on CD-Media, too. It's a really cool linkage.
Unread 14-01-2010, 13:32
Aren_Hill's Avatar
Build Nifty Things
shhhhh
A guy who likes robots.
Unread 14-01-2010, 18:27
AKA: Mitch guzman
We must be thinking of a different idea. We are using tension on some surgical tubing to pull our kicking mechanism back. the winch cable will keep the tension and release it. In order to get lift without extending past the bumper, we are putting a "foot" on the end of our rod. we plan on having a worm gear that will lower and raise the kicking mechanism to get different heights. Then we will have a rubber stopper slightly past the contact point to absorb the force and keep the motor from being harmed. If you still can't see what we're talking about, I can upload a picture of our wooden prototype.
The prototype we build lobbed the ball (height of above 12") for about 12-15 feet. We only used about 80N of force to do this
Unread 21-01-2010, 17:29
eaglecat eaglecat is offline
AKA: John
eaglecat is on a distinguished road
Send a message via AIM to eaglecat Send a message via Yahoo to eaglecat
One idea (we intend to try, disclaimer, have not yet)
Pawl and Ratchet.
Searching the web, have found three sources.
Mc MasterCarr (Page 1053): http://www.mcmaster.com/#6283k24/=5fpwdn
http://www.qtcgears.com/KHK/newgears/KHK316.html
and
https://sdp-si.com/eStore/Direct.asp?GroupID=472
Hope that helps!
- John
Unread 21-01-2010, 17:33
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Consider using a dog clutch type of arrangement?
Unread 21-01-2010, 17:34
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Pawl and Ratchet.
and
Hope that helps!
- John
I've seen a few people bring up the ratchet and pawl system when someone is asking for a way to release a device. I don't understand how a winch with this system will release without backdriving the motor unless another mechanism (dog gear, etc.) is also used.
Unread 21-01-2010, 17:41
AKA: John
Oooh, good call. I had forgotten. I apologize.
Use a "One-Way Locking Steel Needle-Roller Bearing" from Mc Master Carr on Page 1137 or similar.
http://www.mcmaster.com/#6392k41/=5h5e2n
Stick this between the ratchet and the motor shaft.
- John
Unread 03-02-2010, 12:28
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Maybe I'm a bit slow today, but I can't picture how a one way bearing solves the problem of backdriving the motor. The bearing would allow the winch to spin faster than the motor in the same direction. Or did I completely misunderstand your suggested use of the bearing?
Scale Recommendations byrnedfish General Forum 3 27-01-2008 13:27
Winch System SHS Blue Devils General Forum 2 12-01-2008 18:50
Winch Nitroxextreme Motors 10 04-02-2005 00:42
pic: team 60 winch CD47-Bot Robot Showcase 3 01-03-2004 10:36
Winch edomus General Forum 43 21-02-2004 02:30
