Go to Post just flat out, full force, take no prisoners driving - spears312 [more]
Unread 13-01-2010, 21:49
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Code not loading properly
I'm trying to load the built-in default code provided in the WindRiver examples. However, when I deploy it, reboot the cRIO, and try to run it, the Classmate says there's no code. It does detect the stop button and joysticks, so the Classmate doesn't seem to be the problem. I think that the code might not be deploying correctly, although there are no errors when I hit download.
I've installed all the software updates, and set the computer's IP to 10.8.40.6 (team 840), so I don't know what is going wrong...
A few things of note
- the 5V LED on the power distribution block isn't lit. Could this be the problem?
- if I try to connect from the "Remote Systems" tab, I get the following error:
Wed Jan 13 18:47:52 2010
Target name is 10.8.40.2
tgtsvr (VxWorks6x_10.8.40.2@AragonRobotics): Wed Jan 13 18:47:52 2010
WTX Library version: 4.1.1.22
Tgtsvr core version: 4.1.1.17
Wind River Target Server: Win32 version
Connecting to the target agent ...
... switching to WDB4 mode ... ... succeeded !
Loading plug-in for VxWorks... succeeded.
Checking License... OK
VxWorks plugin version: 4.1.1.11
Attaching elf OMF reader for PPC CPU family... succeeded.
Differences for module "vxWorks" segment's address 0x100000:
Offset Target Value Host Value
0x152 0x9c 0x9d
0x153 0x84 0xd0
0x49d 0x0d 0x09
0x49e 0x03 0xaf
Stopping dump. Other errors might exist.
Error: The systems running on the target and loaded into the target server memory are different.
Either wrong core file is selected on the host or text section is corrupted on target side.
Error during target server core initialization
Target Server will exit
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Laptop is not finding the cRIO properly? Studentish Electrical 4 07-05-2009 12:03
1 joystick controls not turning properly andrew_4_life Programming 4 28-03-2008 01:22
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Pictures not loading sanddrag CD Forum Support 32 11-10-2002 01:55
