Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 13-01-2010, 22:13
Robotbug's Avatar
Robotbug Robotbug is offline
Lovely user. =D
AKA: Kaela.
FRC #0753 (High Desert Droids.)
Team Role: Photography
Robotbug is an unknown quantity at this point
Offence vs. Defence.
My team is really debating on focusing on either defense or offense?
Is your team focusing on one or another? Or both?
Are you focusing on going over the bumps/under the tunnel?
Or staying in your section of the field?
Pros/cons for offense vs defense?
Unread 13-01-2010, 22:16
hotapay42 hotapay42 is offline
FRC #2450
hotapay42 will become famous soon enough
Re: Offence vs. Defence.
"From a certain perspective, defense and offense encompass nearly identical tactics."
--Kavier Harkonnen
-Address to Salusan Military
this is from an amazing book: The Butlerian Jihad (part of the Dune series)
Unread 13-01-2010, 22:27
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
As noted above some actions are both offensive and defensive. In the middle, by moving the balls to your offensive zone, you are fueling an offense, but also denying them to the opponent, thus said action is both. Also, the act of pinning can be used for both (stopping someone from pushing a ball in or keeping them out of the way of a shot).
As for offense/defense in general? It depends on your thinking. Obviously if your alliance can't score, you can't win, which would suggest offense. However, on the flipside, if the opposing alliance can't score, it can't win, suggesting defense.
The one thing that I'll say is that a lot of the time, defense gets overlooked. It has no really measurable characteristics. Sure you can count how many blocks it makes, but how much value does an action like pinning add? Because you're looking for the absence of opposing scoring it's hard to quantify defense.
Offense is much easier to measure since it is just "how many points can they score." This will probably get more attention from teams, but likewise, many teams will be doing it, and to stand out, you will have to be quite good (although this is true in any case).
As an example, in the 2008 game, Overdrive, I was wondering the entire Championship (and even before that) why some teams didn't play just to "harrass" (play defense) because they couldn't hurdle. I think it was certain penalties to be avoided, but in the end, it could make a huge difference (if you're familiar with the game, if I were to punch your trackball back over the line after you crossed, you had to go around once and take it back around before you could get points for it again). Almost every alliance picked based on points scored, which ignored that there were only two game pieces for each alliance to score with. At the end when I was getting on the bus, a group was walking by talking about how they should have picked a lap bot that could run and annoy the other team.
Defense is great, but often doesn't get the attention it deserves (although by the nature of this game, it very well might).
Unread 13-01-2010, 22:33
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
My team chose offense, for two reasons:
1. A robot can do at least acceptable defense no matter what (exept maybe if it had an omni drive, which ours does not), but a robot that is built for defense won't be able to play offense very well.
2. Defense is bad. Due to the scoring system in this competition, the higher scoring a match is, the more points all 6 teams get. It is much better to help your own alliance get more points than to work at reducing the score of the other alliance.
When it comes to over the bump versus under the tower, I reccomend reading this:
http://www.chiefdelphi.com/forums/sh...d.php?p=898655
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 13-01-2010, 22:44
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
If you are defence, try preparing for defense and midfield so if you get paired with another defense robot, then you can be flexible. For this reason you should be able to go over the humps as this gives you even more flexibility.
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 14-01-2010, 07:41
Alumnus
In seeding rounds this thrown out though, so defense in and of itself isn't bad, its just that in the seeding rounds it can be (although if it keeps your from losing in a round then that's actually better).
Unread 14-01-2010, 08:16
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Everyone thought playing defense in Rack n' Roll was a silly notion. Once robots started playing defense, it became clear that it was the only key to win.
My suggestion: Play offense, but always defend.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 14-01-2010, 08:28
Chris is me's Avatar
AKA: Pinecone
Defense wins championships. Unless the year is 2005, 2008, or 2009.
I think the best offensive strategies in this game, and the best offensive robots, will play a strategy one might label as "defensive". There are key points in the game where defense is needed to augment offense, and if you don't succeed at them, you won't succeed on the field. This game is going to play out a LOT like Rack n' Roll, with a few less dual lifters.
My two cents.
Unread 14-01-2010, 09:02
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Depends on what you're defending. Opponents' goals? Opponents' robots? Opponents' possessed balls? Opponents' passed/shot balls?
Adaptability will be king in this game. If your robot has design(s) that are adaptable to many uses, success will follow.
At any rate, "offense" and "defense" are much too vague to be employed as strategies.
Hi!
Unread 14-01-2010, 10:28
Alumnus
I apologize for the obvious contradiction in my post. I meant elimination rounds for the first one.
Chris, IIRC, defense was still a contributing factor in 2008. I don't remember seeing 148 do much (on Einstein) besides knock the trackball away from the opposing alliance. If somebody on 148 would like to correct me, but my memory has it that they didn't do much lap running during teleoperated mode, but rather did things like put the trackball back across the line
Unread 14-01-2010, 10:33
AKA: Pinecone
In the years I cited, I meant that an alliance with more offense would almost always win over defense. In 2008, two good hurdlers would beat one good hurdler and two defenders. 2009, three scorers beat two scorers and a scorer-defensive (see Einstein Finals). Other games, the alliance that incorporated defense best into an offensive strategy often prevailed. (Of course, a lot of this is based off of TBA videos / YouTube / Google)
Unread 14-01-2010, 10:51
Alumnus
The thing is that in 2008, only two teams were capable of scoring the big points. Barring breakdowns, two hurdlers and a good defender would beat three 3 hurdlers because only two could hurdle at a time. At that point, my point was that the defender was usually better. I'd have to go back to my scouting data, but if I pushed the ball back over the line (and no g22), even twice in a match, it would have a greater impact than a third offensive bot.
Unread 14-01-2010, 11:17
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Defense is important when used as part of a thoughtful offensive strategy. Defense can and does win matches and tournaments, but a purely defensive robot gets picked into a winning alliance less often than robots that have excellent scoring capabilities combined with the ability to play "heavy D".
Originally Posted by Taylor View Post
Adaptability will be king in this game. If your robot has design(s) that are adaptable to many uses, success will follow. At any rate, "offense" and "defense" are much too vague to be employed as strategies.
100% Correct! Whether you are a defensive or offensive robot, if you only have the ability to do one or two things well, teams will come up with a strategy to succeed against you.
The second statement is far more important to this whole thread. Neither offense or defense wins matches and tournaments... Strategy wins matches and tournaments!
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 14-01-2010, 11:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
In the Qualification Rounds ...
  • if your robot can't do much of anything so your team plays defense then you're shooting yourself in the foot rank-wise.
  • if your robot can score even one or two balls in a match, yet you decide to play defense, you are STILL shooting yourself in the foot.
  • even if you lose the match it is to your advantage to score as much as possible in order to get a higher seeding score.
  • high seeding scores cannot happen if you prevent the winning alliance from scoring alot of points, thus defense will equate to overall lower ranks should you focus on that in quals.
  • the only "defense" should be you taking your opponents balls from their zone and scoring in your goals ... yet if the score differential is too high already then you might as well just score for your opponents anyways.
Thus, a team who's offensive capability is mediocre compared to its defensive capability should focus solely on offense during qualifications and save the defense for eliminations. Ergo designing explicitly for defense implies that you expect your robot's capabilities will be attractive enough to a high-ranked team to be picked; the reality is that those alliance selections are quite unpredictable, especially early in the build season.
Edit -- that does not mean robots should stay away from mid-field defense during quals, since your 'bot jockeys for position in order to feed balls from one side to the other... in elims mid-field will be key since it is only there that balls return back to your offense after being scored. During quals it will simply be more important to keep the flow of balls moving than it will be to push the other robots around.
GitHub
Unread 14-01-2010, 11:54
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
there is also the "Helper bot" option where you focus on helping your alliance climb the tower
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Green and pink painted robot (a good defence?) Sean Raia General Forum 30 06-01-2009 08:53
