Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 13-01-2010, 22:18
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Re: Using a grappling hook to climb the tower
Remember that you can't extend higher than 7 1/2 ft, so if you shoot a grappling hook, it would probably go over that and you would get a penalty. Also, shooting a grappling hook would probably be considered unsafe and not allowed at competition. Instead of shooting the grappling hook, could you try making a small arm that safely extends upwards to get the hook hooked onto the beam?
Grappling hook? Sean Raia Technical Discussion 27 27-01-2010 20:18
How to hook up the tubing with the brass fittings nyindojin Pneumatics 1 02-02-2009 16:47
Using USB with Serial Tower Mick Lego Mindstorm Discussion 11 07-11-2006 09:54
pic: Senior Mentors climb the ramp in Philly RoboMom Extra Discussion 11 08-04-2006 00:19
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
