Go to Post Programming team motto: If it doesn't work, use a bigger hammer. - WizenedEE [more]
Unread 13-01-2010, 22:37
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
pitch of FP motor pinion gear
Does anybody know the pitch of the FP pinion gear? I want to gear a couple of them up for a vaccuum impeller. We hooked up 2 cims to a vaccuum fan and got the same rpms as the original AC motor. Don't want to use up 2 CIMs so we want to make the rig run on 1 CIM and 2 FP's.
Thanks
Bruce
Keyang Motor Spur Gear Pitch Dan Petrovic Technical Discussion 4 24-01-2012 21:35
Keyang Window Motor Gear pitch AdamHeard Technical Discussion 3 19-01-2007 12:12
gear pitch BoticsPUNK Motors 2 19-01-2003 16:53
BOSCH motor pinion pitch Matt Reiland Technical Discussion 2 10-01-2003 09:26
Chiaphua Motor Pinion Gear Joe P Inventor 0 27-02-2002 15:48
