Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 13-01-2010, 22:07
mcristina444 mcristina444 is offline
FRC #2078 (Robotic Ooze)
mcristina444 is an unknown quantity at this point
Exclamation Classmate HELP!!
Today my team set up our classmate pc. we got all the way up to installing the mandatory update. once we rebooted and it logged itself into the driver account it was just a regular Windows Xp interface. is there a special program I have to start to get to the interface that First made?
Unread 13-01-2010, 22:16
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Classmate HELP!!
It should boot into the Driver Station automagically.
Are you sure you logged in to the Driver account? If you log in to the Developer account, you will get the XP desktop.
You can run the LabView Driver Station from the Developer account. It's in the Start menu.
But for practice sake, the best thing to do is log out, then log back in and be sure you select the Driver account.
Otherwise, if that isn't it, you may have incorrectly installed the update. Try to reload that.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 13-01-2010, 22:20
to reload the update would you sugest just rerunning setup.exe or flashing the entire computer using the usb and then re doing everything?
Unread 13-01-2010, 22:21
Doc Wu's Avatar
AKA: Al Gritzmacher
I would try just the update first. Keep the reflash for a last resort.
Unread 13-01-2010, 22:26
ok. thanks. When we installed the update as soon as it said finished i rebooted the computer. Mabe it still had vital processes going at that point. also it asked if i want the devolpers files inaccessible from other accounts. i selected yes. should i change that to no? just thinking it may be a problem!
Unread 13-01-2010, 22:42
Doc Wu's Avatar
AKA: Al Gritzmacher
I don't remember seeing that message, but you would want it accessible from both (or all) accounts.
Unread 13-01-2010, 22:46
it was after setting up a password for the developer account (if you wanted to put a password on it)
Unread 13-01-2010, 22:57
Doc Wu's Avatar
AKA: Al Gritzmacher
Okay, I understand it now. That shouldn't have any effect on whether the Drivers station runs.
Unread 13-01-2010, 23:02
is there a simple exe that i have to run to get the dashboard up? or is it through labview or something like that?
Unread 13-01-2010, 23:14
Doc Wu's Avatar
AKA: Al Gritzmacher
I don't have the Classmate in front of me at the moment, but I believe I remember shortcuts for it being in the start menu.
I do know that the software installed on another computer adds that shortcut. It's called FRC Driver Station. It has a LabView icon.
Unread 14-01-2010, 10:23
CaptainMorton CaptainMorton is offline
FRC #0888
CaptainMorton is an unknown quantity at this point
We had the same problem after reinstalling some labview software to the classmate. We reran the mandatory update that FIRST provided and it fixed the problem
Unread 15-01-2010, 18:44
Does it matter what user you are logged onto when you install the update?
Unread 15-01-2010, 18:59
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
I don't think you can run the update from the driver account, I believe the developer account is the only one capable of more than just running the dashboard and driver station. Of course, you may have configured more accounts (this is probably not recommended,) which could also be used for software updates.
I hope this helps.
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Classmate Issues ROFLcopter NI LabVIEW 10 16-01-2010 21:56
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
classmate help!!! a kenny03 General Forum 1 13-01-2010 20:33
Classmate PC Error scottydoh FRC Control System 2 12-01-2010 14:55
