Go to Post Watch out, guys, Lisa's coming.... worse than any hurricane or tornado you can imagine! - KathieK [more]
Unread 13-01-2010, 22:09
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
Exclamation Using a grappling hook to climb the tower
Yeah... I was just wondering if anyone else was thinking of using a grappling hook to climb the towers on the field. Is this allowed by the rules? It would be lightweight in terms of what it takes to climb the tower and would only require one motor to drive the winch. the only snag we have run into is aiming the hook shooting mechanism so that it will wrap around the bar on the top of the tower.
Thanks.
Ian Heffron
Team 2811 Rules dude
Unread 13-01-2010, 22:17
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Re: Using a grappling hook to climb the tower
you could always press your robot directly flush with the base of the tunnel, then launch it with some sort of pneumatic catapult device...
You could also add fins to the back to stabilize it...
only thing I can say is: if you do that, bring a stepladder in with you at the end of every match, unwinding it will be a pain...
It is definitely possible, but I am not sure what the "safety" of the device would be...
and what sort of damage that thing would do if you missed...(to the floor, and to other robots who might run over it)
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 13-01-2010, 22:18
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Remember that you can't extend higher than 7 1/2 ft, so if you shoot a grappling hook, it would probably go over that and you would get a penalty. Also, shooting a grappling hook would probably be considered unsafe and not allowed at competition. Instead of shooting the grappling hook, could you try making a small arm that safely extends upwards to get the hook hooked onto the beam?
Unread 13-01-2010, 22:19
RaidJTC RaidJTC is offline
FRC #2472 (Centurions)
RaidJTC is an unknown quantity at this point
Our team considered it but the point was raised that if you shot something, there is a good chance that it might hit the ball return bars and you'd get yourself a penalty. If you design it with the guarantee that you won't hit anything but the top of the tower, then your legal I believe.
GaryVoshol's Avatar
Cogito ergo arbitro
Can you throw it so you'll never exceed 90 inches in height?
(since 2004)
Unread 13-01-2010, 22:36
Team 2811's Avatar
AKA: Ian Heffron
Thanks for the information.
I didn't know that you got a penalty for hitting the ball return bars...
There is some special material, i don't know what it is called, but it is a grippy material that is designed to be like gecko skin that you could use as the hook that isn't a hook but just wraps around the bar twice and sticks to the bar.
Thanks
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 13-01-2010, 23:06
BrianCloutier BrianCloutier is offline
Head Programmer
FRC #1011 (Crush)
BrianCloutier is an unknown quantity at this point
Our team decided that a grappling hook was too hard to aim, to slow to reset after a miss, and potentially too dangerous to be an option. You might disagree but our primary concern was lifting ourselves from other robots, we want precise aiming so we can prevent our hook/claw from grabbing undesired parts of our ally.
Unread 13-01-2010, 23:22
fIlImOn fIlImOn is offline
FRC #2486
fIlImOn is an unknown quantity at this point
Our team was also considering that option however if you decide to do that one of the cons to it would be that it would be hard to attach yourself to another robot if thats all you had for attaching. and it can also miss their robot and end up hitting maybe some of their wiring or something else giving you a penalty
Unread 13-01-2010, 23:27
Ratablats's Avatar
Ratablats Ratablats is offline
anything that can go wrong will
AKA: andrew
FRC #1736 (Robot Casserole)
Team Role: Student
Ratablats is an unknown quantity at this point
you might try using something like the antennae on a controller to place a hook on the bar. It could be pretty compact but reach really high, and give you more control over where it went. The only problem is that it might not be very strong.
Unread 14-01-2010, 01:02
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
One of our concepts is to have a grappling hook on top of a scissor device. This would place the hook onto the bars and we would then use a winch to pull ourselves up. This method gives us accuracy and a fast reset.
Thanks,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 14-01-2010, 01:17
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
No offense, but I think some of you are over-thinking this one. Shooting methods are way too complex, and theres no guarantee that it will work every time. Some of the newer members/teams might not know this, but this is not the first time robots have had to hang. In 2004, the end game was reaching up and lifting the robot off the ground by pulling on a 10' high pole. The way my team did it was we had a telescoping pole that reached up and attached a grappling hook to the bar. then the hook was attached to a cable which winched the robot up, sepperate from the pole. See here for our robot hanging
http://www.team811.com/photo/main.ph...g2_itemId=2985
I hope this can be of some help to everyone, and good luck with design and construction!
Unread 10-02-2010, 16:40
baihooli3022 baihooli3022 is offline
None #3022
baihooli3022 is an unknown quantity at this point
heh, we had the same thought here at Team 3022. What we currently are doing with out hook system, is a simple car antenna that we purchased. We just put the hook on the end of the antenna, let it rise up, and drive forward to hook the antenna on. Afterwards, we retract the antenna (to protect the antenna), detach it from the hook, and wind up the winch.
Unread 10-02-2010, 17:00
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Good Idea. Was it hard to change the motor in the car antenna to a KOP motor?
Grappling hook? Sean Raia Technical Discussion 27 27-01-2010 20:18
How to hook up the tubing with the brass fittings nyindojin Pneumatics 1 02-02-2009 16:47
Using USB with Serial Tower Mick Lego Mindstorm Discussion 11 07-11-2006 09:54
pic: Senior Mentors climb the ramp in Philly RoboMom Extra Discussion 11 08-04-2006 00:19
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
