Go to Post make sure you are having fun and developing yourself, not just learning - gixxy [more]
Unread 13-01-2010, 22:24
ligerbots ligerbots is offline
AKA: Elie GLik
FRC #2877 (Ligerbots)
ligerbots is an unknown quantity at this point
Send a message via AIM to ligerbots
Possible to Adjust Speed
Hey,
I was wondering if anybody knew of a relatively simple method of adjusting the speed or volume of air flow into the piston? Basically allowing the piston to shoot out real fast or to slowly shoot out.
Thanks for your help!
Unread 13-01-2010, 23:49
Re: Possible to Adjust Speed
There are flow control fittings used for this purpose.
http://www.alliedelec.com/Images/Pro...s/499-1574.pdf
Unread 14-01-2010, 01:07
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
Any methods for changing the speed during a match?
Team Leader
Team 1595
Unread 14-01-2010, 01:44
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
From my unprofessional experience with pneumatics, there's no way of adjusting air flow during a match. you can adjust it manually that mark was talking about, but thats a little hard to do when your robot's on the field!
Think of a piston as a light switch... not a dimmer switch! A light switch, on/off
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 14-01-2010, 01:50
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
You can do this by using multiple Directional Controls (DC) and multiple Flow Controls (FC). To obtain three different speeds you could use two DCs and three FCs. Remember to only flow control the out flow of the cylinder and not the in flow. Connect the cylinder port to the "P" of DC1 (DC1-P) and FC1 to DC1-A. Connect DC1-B to DC2-P, then FC2 to DC2-A and FC3 to DC2-B. With this arrangement whenever DC1 is de-energized FC1's setting will be used and therefore that speed. With DC1 energized and DC2 de-energized you will get the speed based on FC2's flow setting and thus with both DC1 and DC2 energized you will obtain FC3's setting.
This is fairly easy to program since the DCs are basic binary on and off devices.
If you need more speed settings just add more DCs and FCs in the same "logic". You will have one less DC than FC's. If you wanted say 6 different speeds you could do it with 5 DCs and 6 FCs.
ted yz
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 14-01-2010, 08:17
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
There are a few threads on this already, but we are thinking about using a servo attached to one (both?) of the flow control valves on a piston. Not ideal I know, but it won't require many parts.
Unread 14-01-2010, 08:20
David,
A servo won't give your the range you would need. The flow control valves are needle valves that may require a few turns to get to the desired flow rate.
Unread 14-01-2010, 08:29
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Looking at your problem from a different perspective, you might want to try two air feeds to the same cylinder port, since piston speed will be dependent on amount of air flow. Opening a second feed to the cylinder can increase your piston speed, as it may fill the cylinder more quickly. Limits are imposed by inlet/outlet port size and available pressure, and you should test the concepts by prototyping. Then you can manually adjust each feed to fine tune your speed.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 14-01-2010, 09:57
DavidGitz's Avatar
David,
Al - This is true, but we only need a relatively small deviation in pressure. Thanks though!
Unread 14-01-2010, 10:30
Racer26 Racer26 is offline
Also, you COULD gear the servo up to get more spins out of it. Dunno if the servo would have the oomph to do it is all.
There are better ways to do it using multiple valves. 1075 has in 2004, and 2007 built multi-position pneumatic arms, which could be stopped in mid-travel. by pulsing a feed line, you can cause it to slow down
Unread 14-01-2010, 11:41
Culvan Van Li's Avatar
Culvan Van Li Culvan Van Li is online now
Jack-Of-All-Trades
AKA: Andy
FRC #1939 (Kuh-Nig-Its)
Culvan Van Li is on a distinguished road
You could put a motor and encoder on the pressure valve then control the position of the motor. It's almost trivial with the Jaguar using CAN. The biggest difficulty would be ensuring your start point is where you want it. You could run it to a stop of some sort to make sure you have the position correct.
Another option is to control the duration signal letting the air in. If it takes 250ms for a full stroke, then having an "on" signal that is shorter than that will reduce the power it has when it reaches the endpoint. This is probably the simplest method and requires the least parts, but it requires more fine-tuning to make it work as desired. It might be possible to even pulse width modultate the air intakes to achieve an overall slower speed. Perhaps you would have it forward for 20 ms and backwards for 10 ms and repeat that pattern until it reaches the desired position. This will use more air since you are using the air to oppose the movement of the pneumatic cylinder.
Andy
Unread 14-01-2010, 11:55
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Try searching for "proportional pneumatic valve" on google. There are many different flavors. A common unit I have used for prototyping air actuated brakes on very large robots is a proportional flow control valve such as:
http://www.ascovalve.com/Common/PDFF...PosiflowR2.pdf
We have prototyped this in our system with general KOP pneumatics and it works well to control velocity of the cylinder.
One lesson learned: Make sure you double check the signal voltage before ordering parts.
Unread 14-01-2010, 12:00
Taxi Quinn's Avatar
Taxi Quinn Taxi Quinn is offline
FRC #2389
Taxi Quinn is infamous around these partsTaxi Quinn is infamous around these parts
Help!!!
Can Anybody please private message me and tell me how to post my own thread?
The Big Taxi
Fight, No Flight
"Snarky. Yeah it's a word! Google that...."-Dane Cook
Unread 20-01-2010, 11:55
aziobro aziobro is offline
FRC #4475 (Terrier Byte Bots)
aziobro will become famous soon enough
Is it legal to use more than one valve? This would allow twice the flow rate into the cylinder.
Would you have to make sure that the Cv was smaller?
Unread 20-01-2010, 12:09
aziobro,
The limiting factor is still the volume you can pass through the actuator port.
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Is it legal to adjust CIM's timming? Capt. Quirk Motors 6 16-01-2008 07:35
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
Possible to do multi-speed transmission with v-belt? Squirrelrock Motors 15 13-12-2005 14:44
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
