Go to Post Actually, I forsee two [buttons]: Fire and "Thats the opponents target, you dumb robot" - devicenull [more]
Unread 14-01-2010, 00:08
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
Finale Blocking Strategy
Consider this situation for blocking during the finale period:
A redbot is positioned between a bluebot and the blue alliance tower. Redbot is clearly trying to prevent bluebot from gaining access to the tower. Bluebot pushes redbot into the tower segments that are below the platform level. Rule G35 says "During the FINALE, ROBOTS in may not contact the OPPONENT’S TOWER. Violation: PENALTY for inadvertent contact; plus a RED CARD for obviously intentional contact." Given that redbot was pushed into the tower by bluebot, is this still a penalty?
Unread 14-01-2010, 00:11
cooldude8181's Avatar
cooldude8181 cooldude8181 is offline
AKA: Charlie Davies
FRC #1245 (Shazbots)
cooldude8181 is an unknown quantity at this point
Re: Finale Blocking Strategy
Isn't there also supposed to be only "accidental" contact?
So would the penalties cancel out?
Unread 14-01-2010, 00:14
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I believe another robot cannot force another into a penalty....
Unread 14-01-2010, 01:28
EgROS's Avatar
EgROS EgROS is offline
AKA: Eric Gros
FRC #0624 (Cryptonite Robotics)
EgROS is an unknown quantity at this point
Thats correct.
<G13> Causing PENALTIES – The actions of an ALLIANCE shall not cause an opposing ALLIANCE to violate a rule and thus incur PENALTIES. Any rule violations committed by the affected ALLIANCE shall be excused, and no PENALTIES will be assigned.
TEAM 624 - CRyptonite Robotics
Unread 14-01-2010, 01:35
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
In addition to being against the rules, pushing an opponent into your goal specifically to get a penalty for them isn't really GP, and luckily in this sport, that means that it won't happen very often/at all... Gotta love playing fair!
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 14-01-2010, 01:48
dtengineering's Avatar
AKA: Jason Brett
An interesting question... a possible Q&A question... and a great YMTC (you make the call) starter for the season.
I hope GDC will have a chance to answer this in the Q&A. My bet is that during the finale the intent is to allow teams a chance to climb the tower safely and that "defending" teams will be advised to give the tower a wide berth.
I say penalty for redabot, but not a red card.
Jason
Edit: And, as has often been mentioned, Gracious Professionalism is not a yardstick for measuring others. But I believe it would be totally fair, and in keeping with the nature of the game, to push a redabot into the tower and force them to take a penalty (if, indeed, it turns out that it is a penalty), so long as it doesn't create a safety hazard. Anyone silly enough to play D against a team with a superior drivetrain in this scenario deserves what they get.
Unread 14-01-2010, 02:05
No penalty for redateam, as bluateam pushed them into the tower. <G13> is the correct rule here.
If anything, it might end up being pinning on bluateam, if they hold redateam for more than 5 seconds.
Unread 14-01-2010, 11:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
However, consider that redateam has to play pretty much perfect defense here. If blueateam gets by them at all and touches any part of the tower, then redateam can't touch blueateam or the blue TOWER without a penalty. At which point, I think redateam gives up their defense. Plus, redateam has to be sure it doesn't accidentally brush the tower while defending.
Honestly, if blueateam has a bot to push redateam around, beating this defense is laughably easy. Blueateam just plans on pushing redateam sideways past the front of the tower, so it drive to the side of the tower, turns parallel to the bump and pushes. If redateam tries to keep blueateam from getting beside the bump, redateam gets pushed up the bump, which doesn't sound fun. Then blueateam turns and takes the front of the tower.
So, really, if your robot is going to lose a shoving match... then you should expect to win one. Best redateam can hope is to slightly annoy and slow down blueateam.
Unread 14-01-2010, 11:32
DBortnick's Avatar
DBortnick DBortnick is offline
AKA: Daniel
FRC #1850 (Mechanicats)
DBortnick is on a distinguished road
In the grand scheme of things, if blueateam only has 20 seconds to climb onto the tower and is using a hanging apparatus that takes it 10 seconds to attach and pull itself up, it should be feasible for redateam to stall blueateam into not being able to complete the task even if redateam has an inferior drive system.
Unread 14-01-2010, 13:56
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Just remember that the moment that blue gets in contact with the tower it is effectively invincible to anything except its own alliance and time.
Unread 14-01-2010, 17:39
AKA: Tom Albert
Thanks to all for their comments. This discussion is exactly what this forum should be about. I will indeed see that this gets posted to the Q & A. A few other points to consider:
Bluebot pushing red bot in any fashion which results in redbot contacting the tower means bluebot caused the tower contact. Think of a charging foul in basketball. Whoever establishes their position first should (keyword should)get the call.
If redbot establishes position first, then blue bot will not only have to reach 7 ft in the air but 2 to 3 feet across redbot with their grabbing mechanism.
Bluebot will also have to get over redbot without being on redbot.
Confusing rule: Finale Configuration jackshamu Rules/Strategy 5 10-01-2010 01:34
Championship: Divisioning and Finale merybar General Forum 7 06-04-2008 14:29
In Nats Finale addictedMax Championship Event 12 23-12-2007 22:58
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
Nationals Finale archiver 2001 0 24-06-2002 03:19
