Go to Post Teams must bring their own water. Water must consist of a low viscosity and at it's maximum width must not be larger than 12 in. - Bkeeneykid [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
  #31   Spotlight this post!
Unread 12-01-2010, 04:04
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: Tank Treads
Team 48 has used Brecoflex belts with a lot of success over the years. Several pictures of past systems are available on CD. Some pointers:
  • Keep the belts properly tensioned, but not too tight
  • Protect the tread from sideload stresses as much as possible by using mutiple wheels/sliders along the area of the belt that contacts the ground, and keeping the "open" distance between the wheels/sliders to a minimum
  • Use a belt profile with a middle inner rib as opposed to flanged wheels--we typically used TK10-K13
  • If memory serves me right, we were using an 1880mm long belt with 4" wheels (2" boggie wheels) in our 36"-long tread module, and those belts were about $350...EACH...three years ago
Feel free to contact me if you have any other questions.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #32   Spotlight this post!
Unread 12-01-2010, 08:05
Re: Tank Treads
I have to add something for the teams using tank treads...
Turning on carpet with treads causes extreme electrical loads on your control system. A tight turn is guaranteed to put drive motors into stall. Stall currents on CIM motors is 129 amps each. A four motor drive will draw 516 amps and effectively lower the terminal voltage of the battery by almost 6 volts.
  #33   Spotlight this post!
Unread 12-01-2010, 08:13
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Tank Treads
For some reason, I forgot about team 522, the Robowizards. They used tracks from 2003 to 2008 and they had a very effective system. (World Champs In 2006, IIRC)
Their 2007 iteration was quite clever and it solved the turning issue with the addition of a Ball Caster That was lowered to the ground with a piston and this allowed the drive train to lift itself up onto just the rear most portion of the tread allowing for efficient turning.
Here's a link to their previous robots in the CD Image gallery. http://www.chiefdelphi.com/media/photos/tags/frc522
  #34   Spotlight this post!
Unread 12-01-2010, 08:22
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: Tank Treads
If you look back to the 2004 game, Team 234 used some unique treads that I haven't seen much since. May be a little overkill for this game, but you can check them out here nonetheless - http://www.thistle.uk.com/
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #35   Spotlight this post!
Unread 12-01-2010, 11:56
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Re: Tank Treads
I know that that kind of tread is exactly what most of us had in mind, and personally, I don't find them overkill at all. Especially when you want to be able to tackle the mounds head-on. We were looking for a custom, seamless tread plus components, and have heard rumors of a company who can do this for ~$800 total. Anybody have any leads? Thanks from team 2240.
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
  #36   Spotlight this post!
Unread 13-01-2010, 15:04
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Re: Tank Treads
This may help...
How to build track systems
  #37   Spotlight this post!
Unread 13-01-2010, 17:09
freshrobotics freshrobotics is offline
FRC #1811
freshrobotics is an unknown quantity at this point
Re: Tank Treads
I'd like to know if anyone has any suggestions on where to buy tank treads from McMasters or andy mark?
  #38   Spotlight this post!
Unread 14-01-2010, 10:53
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Re: Tank Treads
379 has had alot of success with tank treads. To my knowledge, we have never broken a tread, at worst, the material on the surface of the tread tends to take alot of abuse requiring a replacement to be on hand. Furthermore, we have always lowered our center idler wheel, which only allows about half of the tread to make contact with the floor and may cause a teeter totter action, but with a little better turning ability.
Tank Treads? reversed_rocker General Forum 7 20-04-2009 19:10
Tank Treads??? SLA Kit & Additional Hardware 2 16-01-2007 20:53
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
Tank treads snowdragon General Forum 0 21-01-2004 16:57
