Go to Post "Trying to teach a nerd to be sensitive to girls is like trying to teach a dog Jamacian, and expect it to talk back" - Hansen302 [more]
Unread 13-01-2010, 17:17
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
2010 Wireless Setup
Does anyone know how to set up the 2010 classmate so it can communicate with the robot through wireless? I couldn't find any documentation to set it up. And how would you set it up to work both with the driver account and the developer account?
There are 10 types of people in this world. Those that understand binary, and those that don't.
Unread 13-01-2010, 17:35
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Re: 2010 Wireless Setup
Section 2 of the getting started manual has that information, chapter 2.10.4
Unread 13-01-2010, 17:36
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
router      robot wireless---cRIO
DS   |
  Dev Laptop
like last year, use same IP setup, just different DS
Watchdog.Kill();
Unread 13-01-2010, 18:37
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
I tried to do this as well. After searching for settings, i realized the Classmates wireless card does not support wireless N.
I'm right 90% of the time, so why worry about the other 3%?
Unread 13-01-2010, 21:08
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
The router supports both 802.11g and 802.11n, so you can use the classmate wirelessly - just make sure you have the router configured to accept both. If I recall correctly the setup instructions tell you to enable only 802.11n on the "main" SSID, so if you don't want to change that just setup a second SSID enabled for 802.11g. The router lets you run two SSID's at the same time.
For example, we setup our router with the main SSID ("2607") on 802.11n only, and a second SSID ("2607-g") on 802.11g only. We leave the main SSID just for the robot bridge to use, and connect programming laptops, etc to the second SSID to keep it clean.
- Ron
Team #2607 controls mentor
Unread 13-01-2010, 21:14
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
It's the same as the old DS. Plug the classmate into the router through the Ethernet port. Make sure in the dashboard you have the team number setup properly as this becomes your IP. For us were were able just to swap the DS's and everything worked fine.
Unread 13-01-2010, 23:58
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Is there a way to use the built in wireless of the Classmate? Not for competition purposes, but for testing purposes?
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 14-01-2010, 09:52
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Unfortunately, the gaming adapter won't connect to a AD-HOC network aka directly to a laptop. The wireless-n router can be swapped with the gaming adapter on your robot and then you can connect directly. I have done this many times for demos. Running 100% unplugged is great!
Unread 14-01-2010, 11:14
The Blue Alliance
This is great to know. Any special configuration settings needed?
Eugene Fang
Unread 14-01-2010, 13:33
Kingofl337's Avatar
AKA: Adam
Nope, just plug the cRio into one of the 4 Ethernet Switch Ports. Don't plug it into the Internet Port, it won't break anything but it won't communicate.
Unread 14-01-2010, 15:37
You also have to either have a laptop with Wireless-N, or you have to setup the router in mixed mode on the 2.4ghz band for the classmate to connect to it.
Unread 16-01-2010, 00:58
Al3+'s Avatar
Al3+ Al3+ is offline
ARTist
AKA: Anthony
FRC #0840 (Aragon Robotics Team)
Al3+ is a jewel in the roughAl3+ is a jewel in the roughAl3+ is a jewel in the rough
Hm... one of our team members "borrowed" the router to connect to the Internet, which has been quite a convenience so far because we only have one Internet computer otherwise.
I don't know much about routers, but am I right in thinking that we'll have to give up the Internet access to set up wireless with the robot?
.. sorry if I'm kind of hijacking the thread. Maybe I should've made a new one.
cout << "Hello, robotics. Goodbye, world." << endl;
"The two-axis accelerometer provided in the kit of parts (shown in the picture below) is a two-axis accelerometer." - WPILib User's Guide
Unread 16-01-2010, 14:16
adamzg adamzg is offline
AKA: Adam
FRC #3932 (Dirty Mechanics)
adamzg is an unknown quantity at this point
We're in the process of troubleshooting the issue with connecting wirelessly to the router from the classmate. When we searched for wireless networks we had the same problem others have had - the router wasn't showing.
We enabled the 2.4 Ghz band and the classmate was able to see the router. We checked this with several laptops as well. It seems like only newer wireless cards will see the 5Ghz band.
Wireless Thermometer Wireless Data C222 Technical Discussion 9 11-01-2010 08:01
Camera Setup ExarKun666 Control System 10 25-02-2009 19:18
Network Setup Problem aoconnor FRC Control System 3 17-01-2009 16:19
WI Setup Timelapse Kevin Kolodziej Regional Competitions 2 08-03-2007 10:32
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
