Go to Post ...if most of the money comes from sponsors, I have a bit of a problem letting them [the students] charge off a cliff with it. - TimCraig [more]
Unread 14-01-2010, 12:39
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: cRio Code problems
The reason it complained is because they don't match. The fix is certainly not to edit the number it's looking for.
You need to make sure the Java Update version and the cRIO image actually match.
Have you installed the update that includes the current cRIO image (v19)?
cRIO update 3.0 problems Two-Face Programming 3 14-02-2009 10:06
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
