Go to Post If you need persuasion woven tight with logic, leave it to a software architect. - Richard Wallace [more]
Unread 13-01-2010, 11:29
Aaron V Aaron V is offline
FRC #1325 (Inverse Paradox)
Aaron V is an unknown quantity at this point
cRio Code problems
We're having problems putting code onto the cRio. We're using the same laptop that re-imaged the cRio, so it shouldn't be a connection issue.
Originally the code would tell us that we had the wrong version info, so we modified line 41 of the upgrade.xml file to become:
<version name="Name" value="FRC_2010_v9.zip;"/>
since it seems like we have version 9 on our cRio.
After we modified this, instead of creating an error, the code is stuck up on
"Setting up for RUN".
Here is the output:
init:
init:
No to.jar.file specified.
Using "suite\InverseParadoxSimple_1.0.0.jar"
Deleting directory C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\build
Deleting directory C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\suite
Deleting directory C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\j2meclasses
clean:
Created dir: C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\build
Compiling 1 source file to C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\build
compile:
Created dir: C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\j2meclasses
preverify:
Created dir: C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\suite
Building jar: C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\suite\InverseParadoxSimple_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Romizer processed 70 classes and generated these files:
  C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\image.sym
  C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\image.suite
  C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\image.suite.metadata
  C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\image.suite.api
Expanding: C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\suite\InverseParadoxSimple_1.0.0.jar into C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\suite
Moving 1 file to C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\suite
Deleting: C:\Users\Robotics\Documents\NetBeansProjects\InverseParadoxSimple\image.suite.api
Connecting FTP @10.13.25.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Setting up for RUN
Unread 14-01-2010, 12:39
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: cRio Code problems
The reason it complained is because they don't match. The fix is certainly not to edit the number it's looking for.
You need to make sure the Java Update version and the cRIO image actually match.
Have you installed the update that includes the current cRIO image (v19)?
Unread 14-01-2010, 12:59
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
This update MUST be done for it to work, and can be found here:
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
cRIO update 3.0 problems Two-Face Programming 3 14-02-2009 10:06
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
