Go to Post The rule is the rule because it is the rule. - dtengineering [more]
Unread 06-11-2001, 11:15
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
simple engineering question
I'm working on a LEGO Mindstorms bot, and I have two motoers using 12tooth bevel gears to use one output shaft to turn two, wich in turn turn tow more, which move the wheels (in essence: one moter per two wheels.
I'm mounted a claw, which is powered by a geabox, but i need more torque in the drive system. I was thinking of improving the ratio from 1:1 (12t to 12t) to 1:3 (8:24) but i have a 12t bevel on the same shaft as the 24.
my question is this: is there a formula for finding out the gear ratios of gears on different shafts, when a third gear to being powered by the first?
Think of it as an 8t gear, driven by a motor, turning a 24t gear, turning a sahft with a 12t bevel. How much torque am i getting? is there a formula out there? I've looked all over the 'net, and can't find a thing. Thanks.
--Ben Mitchell
Simple question for blog/livejournal/etc users.. Joel J Chit-Chat 7 18-07-2003 02:38
Auton Mode simple question Morgoth Programming 7 10-02-2003 10:10
simple question... answer it archiver 2001 1 24-06-2002 01:02
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Canvas in Delphi - Simple question archiver 2000 1 24-06-2002 00:30
