Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
  #31   Spotlight this post!
Unread 14-01-2010, 12:32
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
Re: ELEVATED but not hanging?
Originally Posted by Paul Copioli View Post
All,
We usually bash the GDC when they vaguely word a rule so I will give them credit where credit is due. They really were very clear in the definitions of ELEVATED and SUSPENDED. Direct contact with tower or platform and above the platform = ELEVATED. Only in contact with an ELEVATED or SUSPENDED robot and above the platform = SUSPENDED. This is so obviously clear to me.
Paul,
I agree with your analysis of the definitions but I am wondering if you really need to be above the platform to be a SUSPENDED robot. When I look at the definition of SUSPENDED it does not refer to a height off the field surface. It just says that you are ONLY touching a ELEVATED robot. Maybe there is a opportunity there if the SUSPENDED robot doesn't need to break the plan of the top of the platform.
Some things I have been thinking about:
- If you are a previously SUSPENDED robot but then touch the tower by accident I don't think you would still be SUSPENDED based on the definition.
- If in the process grabbing onto a ELEVATED robot you move them so that they are not above the plane of the PLATFORM, they would no longer be ELEVATED and you are no longer SUSPENDED from a ELEVATED robot.
What are peoples thoughts on this? My first thought is you may want to be careful as a potential SUSPENDED robot because you could negate the ELEVATED robot if the above proves out to be true.
  #32   Spotlight this post!
Unread 14-01-2010, 12:35
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
I agree, the endgame rules are very clear this year as long as you don't over think them or try to infer meaning. Just go with exactly what the rules say. Nothing more, nothing less.
So I must ask why you think a SUSPENDED robot must be above the platform? The rule for SUSPENDED only deals with contact, not position.
  #33   Spotlight this post!
Unread 14-01-2010, 12:58
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Mike, Paul and all others:
I am going to go against the grain here...call me a rebel.
The GDC has said in the past not to "lawyer" the rules, but to look for the intent. My opinon remains that the GDC's intent is to have robots using some kind of hook/latch/bent piece of metal mechanism to enable the robot to elevate itself to a point above the "normal" playing surface. (normal playing surface= the flat carpet from which the bumps and towers protrude) Whether that hook is on the horizontal bar at the top of the tower, clamped onto the vertical post of a tower or attached directly to another robot and is above the level of the platform or above the "normal" carpet in the case of attached to another robot.
If the GDC rules in the FIRST Q & A that rolling out a lexan tongue is legal, I will bring cupcakes to Atlanta.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
  #34   Spotlight this post!
Unread 14-01-2010, 13:05
Brandon Holley's Avatar
Preface: I know the game animations have errors from time to time
watch when the one red robot hangs from another...it does NOT break the plane of the platform. Combine that with the lack of rules stating a suspended robot needs to be above a certain height. The result is to be suspended you can only touch another robot and that's it.
I agree with Paul, the rules are clear. I do not see the argument to the otherside.
Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #35   Spotlight this post!
Unread 14-01-2010, 13:15
President, VEX Robotics, Inc.
All,
See my edit in my above post. The SUSPENDED robot does not have to be above the platform. I knew this, but my typing got ahead of my brain. Sorry for the confusion.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #36   Spotlight this post!
Unread 14-01-2010, 13:18
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Alright, I've been holding back long enough, but I have one.
Your robot gets on top of and sits on the platform. It is now ELEVATED.
ELEVATED: A ROBOT that is completely above the plane of the PLATFORM and in contact with the TOWER shall be considered ELEVATED.
Your robot throws down a large piece of carpet/fabric that is still attached to your robot and remains inside the 84" cylinder onto the ground from the top of the platform where it is ELEVATED
Brandon's bot drives over on top of my carpet/fabric. It is now SUSPENDED.
SUSPENDED: A ROBOT only in contact with an ELEVATED ROBOT and/or a SUSPENDED ROBOT shall be considered SUSPENDED.
5 points?
  #37   Spotlight this post!
Unread 14-01-2010, 13:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Your carpet is now below the plane of the platform so you are no longer ELEVATED.
0 points.
  #38   Spotlight this post!
Unread 14-01-2010, 13:58
AKA: Jacob Komar
0 points.
Right.
*crawls back into programming cave*
  #39   Spotlight this post!
Unread 16-01-2010, 20:31
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
If our robot seizes a willing alliance robot tightly and THEN elevates by whatever method it can, it is my supposition that our alliance will get 5 points for the effort. This avoids the necessity for collaboration on attachment strategy with random other teams (as will happen in Q-round). In designing our seizing mechanism we need only consider the commonality of other robots' designs. Something like the little bars to wheel hoists on the modern-day tow trucks. Those guys don't ever know what kind of bumper or fenders or frame is going to be on a car they're called to tow, but they do know that it has wheels on the ground that are no larger than x inches and not likely to be further apart than y inches. Hence the forking interface to their ultimate hydraulic lift. Anything else besides wheels on this year's robots that is so predictable?
  #40   Spotlight this post!
Unread 16-01-2010, 23:50
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Paul is wise. Listen to Paul (this from the guy that Paul yells at every year at IRI for the stupid rules ).
I, for one, am looking forward to cupcakes in Atlanta.
-dave
  #41   Spotlight this post!
Unread 23-01-2010, 13:07
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
From what I have learned is that you are considered elevated when you are only touching the bar thats supposed to be grabbed on. You are considered suspended if you are not touching the tower and are hanging off of another robot you are considered suspended. So in theory having a stack is not applicable. Sorry if this hurts your plan but this is what I have heard. If I'm wrong then tell me so that I know about this. Also my friend is bugging the crap out of me about my grammar. Thanks for reading and tell my friend to stop bugging me. BYE!
!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~ !~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~ !~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~ !~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~ !~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~ !~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~ !~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!~!(All done now)
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
  #42   Spotlight this post!
Unread 23-01-2010, 13:16
solost4words's Avatar
solost4words solost4words is offline
The imaginitive one. :]
AKA: Rachael Hartman
FRC #0302 (Lake Orion Dragons)
Team Role: Electrical
solost4words is an unknown quantity at this point
Send a message via AIM to solost4words
Wink Re: ELEVATED but not hanging?
Well, that sounds about right to me. Even if you were to stack on other robots, I think it would be incredibly difficult to accomplish.
And, no, Brian, I will not stop bugging you about your grammar. Make it better, and I'll consider it! XP
Bubbly never sounded so good.
And it starts at the goal, and I lose all control
And we get yelled at, by safety patrol
The robot gets thrown, and the pieces are blown
They're scattered all over, the middle zone
Then we beg on our knees, still we get penalties
I see magic smoke, and Dean has a stroke
But we get restored, with the Chairman's Award
We'll be up all night
  #43   Spotlight this post!
Unread 23-01-2010, 13:50
GaryVoshol's Avatar
Cogito ergo arbitro
When you're done checking your grammar, and done posting nonsense symbols, you might want to go back into section 7.2 of the manual and check the definitions of ELEVATED and SUSPENDED.
(since 2004)
  #44   Spotlight this post!
Unread 23-01-2010, 14:11
Brian Ha's Avatar
Teh Ha Kid
Team Role: Driver
Ok if you don't agree with me. Explain how you would stack 3 robots on top of each other?
  #45   Spotlight this post!
Unread 23-01-2010, 14:12
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
KGood is an unknown quantity at this point
They might correct this in a rule update, but the GDC has a habit of leaving some rules open to ambiguity to let teams be creative.
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
Elevated bots DNay247 Rules/Strategy 10 13-01-2010 19:53
Camera moving but not tracking ijk90825 Programming 3 31-01-2009 14:40
Camera tracking but not moving penguain NI LabVIEW 9 30-01-2009 10:10
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Hotels not in but around Disney archiver 2001 2 23-06-2002 22:18
