Go to Post I can't wait to get to St. Louis!! Oh wait.. I'm already here!! - Team 288 [more]
Unread 14-01-2010, 09:35
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
force required to spin vaccuum fan
Anybody know a way to figure out the force needed to spin a vaccuum fan at a given speed?
Bruce
Unread 14-01-2010, 09:58
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: force required to spin vaccuum fan
Bruce
That depends on a LOT of things, such as prop angle, prop size, RPM needed, Drag coeffecient, Amount of airflow wanted/needed, etc, etc ...
How much vacuum are you looking to pull? and how much volume are you looking to evacuate?
___________________
- Tennyson, Ulysses
Unread 14-01-2010, 11:02
Bruceb's Avatar
I have a 120 volt 5.7 amp shop vac that seems to handle the soccer balls well. I want to use the JVN design calculator to figure gear ratios to drive it at the same speed using 1 CIM and 2 FP motors so I need to have some number to plug in the formula for force required to spin it.
Does that help?
Bruce
Unread 14-01-2010, 11:30
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Also, remember that the load on the motor will be greatest when moving air before your block air flow. As the vacuum is developed, the air resistance decreases and the lowest loads will be when the impeller system is rotating in a near complete vacuum.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 14-01-2010, 11:38
REVving up for a new season
FRC #2848 (All-sparks)
Also I would like to point out there are 2 underlying concepts that define each vacuum's performance. Flow (CFM) and Static Pressure ( in-H20). Each one of these things brings something different to the table to create a concept known as Air-Watts. A vacuum impeller/motor combo can be configured for many different applications and the cost of the vacuum is directly dependent on this factor. Most Sub $100 vacs are designed with Flow in mind, as the average consumer interprets high velocity of air as power. The real thing is the static pressure, which determines the "mussel" of the vac.
If you are planning on stripping the blower out of a Vac try to get one with a higher static pressure and lower CFM, That combination will allow you to hold on to the ball better with a lower power consumption than one that has both a high CFM and static pressure.
If teams are interested in just getting the impeller/motor instead of the entire vac, check out AMETEK http://www.ametekfsm.com/ as they are the industry leader and you will probably save money then getting a vac a home depot and tearing it down.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 14-01-2010, 14:09
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
in 2008 we used 2 FP motors to drive a shop vac blower to good success.
Here is another picture.
We were driving it at 1:1 and had to vary the speed of the motors because we were generating too much suck. I mean we couldn't get the ball off the manipulator at full speed.
Former Mentor Team 1771
Former mentor Team 4509
Unread 14-01-2010, 15:19
Bruceb's Avatar
Martin, how did you adapt that belt sprocket to the FP motor shaft?
Bruce
Unread 14-01-2010, 15:46
martin417's Avatar
AKA: Martin Wilson
Bruce
It's just a timing sprocket from Stock Drive Products. It has a setscrew to hold it on the shaft. If I remember correctly, we may have had to enlarge the bore slightly due to the knurling on the FP shaft.
Unread 14-01-2010, 16:01
martin417's Avatar
AKA: Martin Wilson
Another though on vacuums: some are single stage, and some have two or more. A single stage will have one rotating disk, while a two stage (like the one we used) will have two rotating disks separated by a stationary flow straightener. A single stage will flow more air at a given size and power, while a two stage will create a higher static pressure differential.
If you can get a two stage, you will probably be better off in this game because the ball area is relatively small.
Unread 14-01-2010, 17:44
Bruceb's Avatar
What kind of devices have a 2 stage vac?
Bruce
Unread 14-01-2010, 20:03
martin417's Avatar
AKA: Martin Wilson
Bruce
Ours came from a shop vac, but my old Rainbow at home has a 2 stage impeller also.
Unread 15-01-2010, 22:33
Bruceb's Avatar
Martin, what belts did you use. Is the cheapest o.k.?
Bruce
Unread 15-01-2010, 23:14
DonRotolo's Avatar
Back to humble
FRC #0832
Cheapest is always just that: Cheapest. Over the years we have found that Best tends to work better and last longer. Build using the highest quality components you can afford.
Of course, for prototypes, cheap is usually fine.
Unread 16-01-2010, 07:27
martin417's Avatar
AKA: Martin Wilson
Bruce
Avoid "shade tree engineering"! Don't just guess and try it, the build season is too short!
Belt manufacturers publish data on capacity of belts, advantages of construction and materials, etc. The data is often in the form of a graph, plotting belt capacity (in horsepower) against the speed (in RPM) of the fastest pulley. do not exceed the spec.
You should also look at the max torque. You will probably have to ramp up up the speed of the motor to avoid slipping the belt or the pulley.
A different spin on things. Matt Attallah Chit-Chat 28 24-07-2006 11:38
Will the tetras spin? SteveO Rules/Strategy 15 20-01-2005 02:36
Bad spin-offs of Good threads Mike Heinowski Games/Trivia 5 12-10-2004 15:58
PUSA and Spin Doctors Jeff Rodriguez Chit-Chat 1 08-08-2003 03:37
Motor Spin Direction archiver 2000 6 23-06-2002 23:43
