Re: pic: Team 2791 Modular Chassis
Yeah I have considered 3/16" Al. Not 1/8", do you think that would be strong enough?
You want your designs to be strong by the nature of their shape, rather than just adding more material. |
OK, talking about standoffs I forgot to mention that the axles are going to be standoffs. My content center is not loaded on Inventor but I am going to use 1/2" through bolts for axles, then utilize spacers to keep the wheels aligned.
Not a bad prototype. Didn't know I had such talented teammates.
Would this be easy to throw AM or laser cut floating tensioners on? |
Thats the plan.
) to much success. Here's a photo of our 2009 practice robot frame:![]() |
#7
I like it! Looks like a very solid start. Some things to keep in mind:
-Chain tension. Are you tensioning the chain, or have you run your numbers on sprocket distance? -Support. How much support do the two plates have between them? -Live or dead axles? -How quickly can you repair it if or when it breaks? Looks like a solid start! |
| pic: 2791 Final robot | yodameister | Robot Showcase | 13 | 21-02-2009 23:45 |
| pic: What is 2791 up to? | yodameister | Extra Discussion | 10 | 02-02-2009 18:21 |
| pic: Rookie 2791 progress | yodameister | Extra Discussion | 10 | 27-01-2009 21:45 |
| Team 1583's 6 wheel modular drive prototype | NOV8R | Robot Showcase | 8 | 08-01-2008 11:57 |
| pic: Team 116 Modular Control System | dlavery | Robot Showcase | 42 | 21-10-2007 11:15 |
