Go to Post But please take into account that each year, the GDC has to come up with a rule book that will spend the next three months being picked apart by 40,000 of the brightest, most creative minds on the planet. I think they do an outstanding job of it. - dtengineering [more]
Unread 08-08-2002, 03:14
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
Re: Friction, traction, torque - oh my...
On the note of friction and traction - I've heard a lot of teams pulling the "f = uN" stunt recently. That doesn't work. Tell me if this logic is correct - carpet is not a surface. It's a conglomeration of threads strung together, and so you can't accurately test any sort of friction. Also, if you have things like file cards (which have next to no traction on any other surface) they dig into the threads and latch on, and don't really count as traction...
Carpet is indeed a surface but F=uN is not the correct equation for dealing with rolling friction. Take drag racers, for example. In a physics lecture, they will explain to you that if you have a box of uniform substance that has more surface area on one side and less on another, it will take it the same time to slide down a hill on either side. Why do drag racers have big tires then? Surface area does matter when it comes to wheels.
~Tom Fairchild~
P.S. Carpet is a surface but things like the file cards just have very high u's. If you experiment with it, you can get fairly consistant static friction and kenetic friction measurements. Once again though, that doesn't work for rolling friction.
Former member of Team 122
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Results of traction test IBApril180 Technical Discussion 3 04-01-2003 18:56
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
