Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 14-01-2010, 18:00
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
cRIO Firmware Update?
We are trying to run code from the 2010 Classmate on the cRIO, but we are getting the error that the cRIO has different software installed, has there been a firmware update, and if so, where would we be able to get it?
Here is the exact error message:
Access denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explore.
driver station firmware update tanguma26 Programming 1 14-02-2009 19:53
driver station and cRIO firmware update help asianfez123 FRC Control System 1 16-01-2009 02:34
Do we have to update firmware? Emily M. FRC Control System 7 09-01-2009 18:34
updating firmware on crio nickmagus Programming 16 17-12-2008 16:58
Firmware update Cuog Programming 2 21-02-2006 20:28
