Go to Post I think these new rules are making the message coming from FIRST perfectly clear - engineering is about what happens between your ears, not what comes out of your deep pockets. - KenWittlief [more]
Unread 10-01-2010, 20:24
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
2010 Accelerometer Documentation?
Does anyone have any information on the accelerometer that we were provided in the KoP this year?
The WPILib user's guide tells us that it's I2C based, but that's all the information I can find. The kit checklist just shows a picture, and there's no documentation on the FIRST site as there is for the gyro and encoder, not even a part number. I haven't had a chance to actually look at the board to search for anything that could help.
So, for now, we have no idea how to even hook it up, not even going on to actually reading it and using the data (hopefully WPI's "shortly after kickoff" will be soon), unless I've missed something. Is everyone else in the same situation?
Unread 10-01-2010, 20:33
Re: 2010 Accelerometer Documentation?
It is documented in the 2010 Sensor Manual
http://usfirst.org/uploadedFiles/Com...r%20Manual.pdf
Unread 10-01-2010, 21:28
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
It would be great if there were a page where you could find this link. Where did you come up with it, Eric?
Unread 10-01-2010, 21:50
I found it under section 8 of the manual's jump page: http://usfirst.org/roboticsprograms/...nt.aspx?id=452
Unread 10-01-2010, 22:33
I wonder why the data sheet for the Gyro and the AS5030 are not also on that jump page.
Unread 10-01-2010, 22:55
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
They're under the Section 10 subgroup on here: http://usfirst.org/roboticsprograms/...nt.aspx?id=452
Unread 11-01-2010, 10:23
JDM JDM is offline
Wow, I can't believe that I didn't even think to look for that
Thanks alot!
Unread 14-01-2010, 19:34
altf2junkie's Avatar
altf2junkie altf2junkie is offline
FRC+FTC Teams 339, Kilroy + Vulcan!
AKA: Samuel Vladimir Pakington
FRC #0339 (Kilroy)
altf2junkie is an unknown quantity at this point
A question, not about the accelerometer but rather about the gyroscope:
We looked at the pin configuration on the documentation that FIRST sent us, and while the picture of the gyroscope looks exactly like the gyroscope we received, the pin configuration doesn't match the structure of the gyroscope at all.
For instance:
In the schematic, the Temperature and Voltage outputs are on opposite sides.
On the gyro, there are three Temperature and three Voltage outputs, and they lie next to each other in two rows.
Can someone help us? Is the documentation / gyroscope incorrect? Or are we just missing something?
And as a side note, if you do know, how would we wire the gyroscope using a PWM?
Regards, Team 339 Kilroy (FRC)
Unread 14-01-2010, 19:51
For instance:
The pin structure is as follows:
Rate           Temperature
5 Volts        5 Volts
Ground        Ground
Wire your PWM cable such that the white signal line goes to either rate or temperature, the red power line goes to 5 Volts, and the black line goes to ground.
The signals are closest to the signal names: The ground is closest to the edge of the board.
I'll try to update the doc.
Unread 14-01-2010, 20:18
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Istheir a test VI to test the accelerometer using I2C in the cRIO code this year?? The one I found was only for testing last years unit using analog inputs??
thanks...
anyone have any test code??
Unread 14-01-2010, 20:27
FRC #0339 (Kilroy)
Thanks for the fast response.
Should have specified - we need to know which way to solder the PWM to the gyro, not the gyro to the digital board. Thanks for the additional information, though.
We have one PWM space for Rate and another for Temperature.
We figure that we won't need to use temperature, so all we need to know is which way to orient the PWM (white wire out, or black wire out?).
Unread 14-01-2010, 21:00
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Emphasis mine. Just read the post a bit more carefully.
Unread 15-01-2010, 00:18
thanks...
Depends on your language of choice. I added 2 examples for using the ADXL345 one with I2C and the other with SPI, both for LabVIEW. I haven't seen any examples for C++ or Java yet. What language are you trying to use?
Unread 18-01-2010, 12:42
bcieslak
Posts: n/a
Here's an interesting App Note if your trying to figure out what to do with your Accelerometer once you get it working.
http://www.analog.com/static/importe...es/AN-1023.pdf
Make sure to checkout the I2C threads on chief delphi too. There is some discussion of NI's implementation of I2c in the FpGa.
Bc
FRC Java 2010 Documentation alivemyst Java 11 07-09-2009 19:03
Documentation Blocker-9 Technical Discussion 1 26-01-2004 19:21
RC documentation rbayer Programming 2 24-12-2002 03:10
Documentation archiver 2000 2 23-06-2002 22:41
Documentation archiver 2000 1 23-06-2002 22:22
