Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
  #31   Spotlight this post!
Unread 13-01-2010, 22:28
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: 2010 Camera and vision problems.
Originally Posted by Kingofl337 View Post
Seeing Java and C++ use pretty much the same code base, I'd think it would work in one if it works in the other, I can test the C++ code tomorrow night.
If the C++ code does work, is there any way you can put together a list of what we might be doing wrong? I'm getting nowhere fast as of now.
  #32   Spotlight this post!
Unread 14-01-2010, 08:49
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
With Java, it pretty much went.
Download: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534 and install it
Update cRio Image to v19 (Tick Format Controller)
Plug Camera into Laptop and Run Config Utility
Plug the camera into the robot using Port 2 and a Crossover Cable
Pull down the Netbeans plug-ins
Run the source code I posted on the last page
I'd assume it would be the same for Wind River, except you would need to download the update from http://first.wpi.edu/Images/CMS/Firs...te20100107.exe for Workbench.
  #33   Spotlight this post!
Unread 14-01-2010, 09:31
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Hmm, only difference between your list and mine is that I manually edited the username and password rather than use the Config Utility. Does the Config Utility change anything else on the camera? I'll give running that a shot once I get into the lab and post results.
  #34   Spotlight this post!
Unread 14-01-2010, 09:43
Kingofl337's Avatar
AKA: Adam
Something else you may want to try, if you used Wind River last year is to uninstall it and delete all traces of it. Then reinstall, I think the location of WPILib.a moved down a directory and Wind River could be pointing to the wrong file.
You may also try searching for WPILib.a under C:\Windriver and deleting it, after that reinstall the Workbench update. If it can't find WPILib.a then that's your issue and you need to point to the current location. If you were using WPILIb source code to compile you WPILib.a file that can cause the issue as well. I haven't seen the new version of WPILib source yet.
  #35   Spotlight this post!
Unread 14-01-2010, 12:11
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
Originally Posted by DanDon View Post
Have you gotten the camera to at least instantiate? I can ping the camera (192.168.0.90) with 0% packet loss from the cRio, and the user/pass combo is set up correctly but my code still hangs on AxisCamera::GetInstance().
Yep, I have gotten past that point in the code. Duno if tracking works though because the lens was out of focus and is now dead, so I'm heading over to Fry's to get another one.
The dashboard on the Driver Station doesn't work though.
  #36   Spotlight this post!
Unread 14-01-2010, 15:13
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Still absolutely no dashboard data with the 2010ImageDemo. I'm getting the code to run, however there's an output line on the VxWorks console that worries me.
task 0x1df9a60 <FRC_cameraTask> deleted: errno=0 <0> status=0 <0>
No idea what it means, but it doesn't look promising to me. Any help?
  #37   Spotlight this post!
Unread 14-01-2010, 15:26
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
That means something deleted the camera Task. Usually by going out of scope. Make sure you don't accidentally dispose the camera
Watchdog.Kill();
  #38   Spotlight this post!
Unread 14-01-2010, 20:22
JesterKarrde JesterKarrde is offline
AKA: Grant P. Garner
FRC #3413 (Cowboys)
JesterKarrde is an unknown quantity at this point
I'm working on LabVIEW trying to solve the same problem. I've gotten the image to show up on the LabVIEW instrument, but not on the dashboard. I am getting the image from the cRio.
  #39   Spotlight this post!
Unread 14-01-2010, 20:43
tekman1001 tekman1001 is offline
FRC #2342
tekman1001 is an unknown quantity at this point
Hey does anyone know were the demo code is located I can't find it anywhere.
Thanks,
  #40   Spotlight this post!
Unread 14-01-2010, 22:16
woodk woodk is offline
FRC #2809
woodk has a spectacular aura aboutwoodk has a spectacular aura aboutwoodk has a spectacular aura about
Some people seem to be having a similar problem to what I had ...
in my case the DSupdate did not update the dashboard (only the driver station). I only noticed because I installed the update on a second laptop and it looked different. I went back and checked the file date and it was not the same on the classmate. I had to run the DSupdate program, but tell it to uninstall, then run it again and install. Now it works.
- Kevin
  #41   Spotlight this post!
Unread 14-01-2010, 22:19
FRC #2809
Thanks,
You should be able to create demo code by selecting File -> New -> Example
Make sure you follow the "Getting started with C++" document the first time.
- Kevin
  #42   Spotlight this post!
Unread 14-01-2010, 22:53
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Reinstalling worked for us!!!!
Thanks guys,
Julian
  #43   Spotlight this post!
Unread 14-01-2010, 23:19
ranc ranc is offline
FRC #2489
ranc is an unknown quantity at this point
Thanks guys,
Julian
Did you reinstall Windriver? or the driver station update?
  #44   Spotlight this post!
Unread 15-01-2010, 18:04
C++0x FTW!
FRC #1771
I finally got camera output + target data on the dashboard. The problem was indeed the drivers station update.
Here's how to fix it:
  1. Download the drivers station update: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
  2. Run the drivers station update and install.
  3. Run the drivers station update and select remove for both components.
  4. Run the drivers station update and install.
This fixes it. NI needs to fix the installer.
  #45   Spotlight this post!
Unread 15-01-2010, 18:25
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
I was just about to post this. Exactly what I had to do to fix the problem.
I also have the camera tracking the target on a pan/tilt assembly .
Vision problems and FIRST members ebmonon36 Chit-Chat 10 21-01-2006 22:43
vision camera Adama Programming 3 19-01-2006 17:12
71's Vision Tracking Problems Bill Beatty Rumor Mill 7 19-04-2005 17:41
Camera Vision Range Muhnki Programming 7 05-02-2005 23:26
