Go to Post If duct tape isn't the answer, you're not asking the right question. - Morgoth [more]
Unread 14-01-2010, 20:55
mandalorethx mandalorethx is offline
FRC #0272
mandalorethx is an unknown quantity at this point
Cannot Download Code
We are using Windriver for C++ development on the robot and I cannot download code to the robot. the cRIO is updated to c-2010_v19 and I have also applied the latest updates to windriver. at this point we are only trying to load example code (DefaultRobot).
IP addresses are correctly assigned and the FIRST downloading preferences are set
I can get the remote registry to connect to the robot, but when I go to FIRST > Download the downloading window comes up and reports that it is downloading code, but the status bar does not come up, it will sit there for a while, but will not download code.
Thank you for any advice you can give.
Unread 14-01-2010, 20:56
FRC #0272
Re: Cannot Download Code
Also, I get the following error across a serial cable at the end of the booting process of the cRIO:
NI-VISA Server 4.5 started successfully.
task 0xe41130 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
Unread 15-01-2010, 03:08
ranc ranc is offline
FRC #2489
ranc is an unknown quantity at this point
try disabling any firewalls you have
Unread 15-01-2010, 11:01
AKA: Brad
#0190 ( Gompei and the Herd)
Just to be sure... you are downloading the ProjectFile.out file in the downloader preferences... Then the program should start on reboot of the cRIO and not when you download it.
Brad Miller
Robotics Resource Center
Unread 15-01-2010, 12:35
ZP8892's Avatar
ZP8892 ZP8892 is offline
FRC #0369
ZP8892 is an unknown quantity at this point
Send a message via AIM to ZP8892
Exclamation Re: Cannot Download Code
Does anyone know the setup required to download a code to cRIO? I am having issues figuring that out. Any help would be greatly appreciated.
Unread 15-01-2010, 12:44
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Complete instructions are in the C++ getting started guide:
http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 09-03-2009 22:10
Cannot Download Code to our Robot jcvd C/C++ 9 27-01-2009 13:09
Can't Download Code nickmagus Programming 1 05-01-2009 17:52
2006 Robot Code Download Chris_Elston Programming 2 05-05-2006 10:42
