Go to Post ... boundless mentory goodness ... - pfreivald [more]
Unread 14-01-2010, 21:03
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Linear Actuator
3132 here,
We're doing some research for our kicker and I'd like to know which linear thruster we should order from Bimba. Also, would this be enough to loft the ball, along with an angled plate?
Also, would a rotary actuator be a better choice based on our size constraints?
Thanks in advance.
Unread 14-01-2010, 21:05
Re: Linear Actuator
What are you looking for in the kicker? Speed, power, minimal air use, or something else entirely?
Tip: Generally, smaller-diameter cylinders fire faster than larger-diameter ones.
Unread 14-01-2010, 21:24
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Linear Actuator
I think a linear actuator would be easier to implement than a rotary one for the situation I think your talking about. As for the lofting the ball, I think your team just needs to do a little experimentation and some calculations to find the optimal conditions, much like most of the teams will be doing.
-Scott
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 14-01-2010, 21:34
Re: Linear Actuator
We're hoping to do just that, but my partner isn't here today so I hope we'll make a start tomorrow. We're in Australia though and ordering parts is a long process for us and this is why a rotary actuator would be suitable for prototyping here as we have one.
Unread 14-01-2010, 21:58
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Linear Actuator
I think a rotary actuator may not have enough "oomph" for you. Try it anyway instead of doing nothing. A linear piston can fire a ball pretty far, but there are some trade-offs to consider.
Small diameter pistons tend to fire faster, because the limiting factor is how much air you can pass through those hoses and valves, and smaller pistons use less air.
But they also push with less force. In the extending direction, for example, a 3/4" bore piston can generate about 26 pounds of force using 60 PSI. (More details are in the pneumatics manual)
Large pistons are slower (more air) but stronger (look up the force for a 2" bore piston!).
One technique is to use a lever with a pivot to multiply the speed at the expense of force. Using a 10 inch bar as an example, push at one end at 20 Feet per second, have a pivot at 2", the far end moves at ((8/2)*20)=80 FPS, with 2/8 (1/4) the force. The challenge is here is to manage the size, strength and friction.
Another technique is to pre-charge the piston: Imagine a 10 inch long piston, held in place somehow with 5 inches extended. Charge the backside of the piston with 60 PSI. Then, release the rod so it can extend the full 10 inches - it'll come out fast and strong. The design challenge here is reliably and safely releasing the rod that is under a great deal of force (obviously some kind of mechanism is necessary)
These challenges have been solved in may ways by others. There are also other ways of "skinning that cat" - but telling you everything would take out the fun, wouldn't it?
Good luck, we're all wishing you the best.
Unread 14-01-2010, 22:05
Re: Linear Actuator
Would the rotary piston have enough "oomph" if we added a counter weight (and some elastics)?
Unread 14-01-2010, 22:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Linear Actuator
My best advice is to try it. Adding a "spring" (even of elastic) can help - I am thinking of using the rotart piston to "pull" the elastic tight, then the force of the piston AND the elastic is used to whack the kicker.
As a first year team, you really need to build a Pneumatics Board. Mount the compressor, gauges, regulators and all the safety pieces onto a piece of wood. Use a circuit breaker (20A) in the power supply. That way, you have a ready source of air to experiment with until you nail down your design.
One more alternative to consider is using the piston to stretch the elastics (use the latex surgical tubing that came in the kit). The elastic then provides the "oomph" - very fast and very repeatable. (A piston force will vary with air pressure. That's a mighty small compressor there...)
Unread 14-01-2010, 22:50
Re: Linear Actuator
We just found out that we have to order the actuators as we didn't get any in our KOP so we'll try and order a linear actuator. Can you recommend a good one for us?
Also, there's a Bimba distributor in Sydney.
Unread 14-01-2010, 22:57
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Linear Actuator
You have to order the pistons from the bimba website, you get three free ones.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2010, 23:03
Re: Linear Actuator
Already know that, but thanks.
Unread 14-01-2010, 23:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Linear Actuator
There are specific pneumatic cylinders ("Linear Actuators" isn't their correct name) that you are permitted to use. Look for the FRC link at www.bimba.com
Basically, you can choose whatever you want from the list of permitted cylinders. These come in varying lengths, and in diameters of 3/4", 1.5" and 2". Look in a previous year's pneumatics manual if necessary, but remember to follow THIS year's rules. YOU need to decide what amount of force is necessary, and how long it needs to be.
Think about the problems and compromises:
Large cylinders are more powerful, but use more air.
(You have an air budget, just like an power budget. That's not a big compressor...)
Small cylinders move faster, but are not as powerful.
Long cylinders need more than twice their 'throw' in distance to fit. A 24" cylinder ends up something like 50" long when extended.
I was thinking: Since you're down under, your robot won't have any trouble flipping back up if it turns over, right? (Or will it run upside down here in the 'states?)
Unread 14-01-2010, 23:22
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Linear Actuator
You can also order 1 1/16 cylinders from the Bimba site.
Unread 15-01-2010, 07:35
kwotremb's Avatar
kwotremb kwotremb is offline
FRC #3414
kwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to behold
Re: Linear Actuator
As far as a size goes, we are using an old 1.5 bore that has been in previous kits and it is kicking the ball just fine with a lever. We are going to order different sizes, but this could help you guys have a place to start.
2013: Team 3414 Hackbots
Waterford District: Finalist (51, 3604)
Livonia District: Winner (3641, 240), Spirit Award
MSC: 6th Seed Captain (862, 3641), Spirit Award
Worlds: Seeded 32 in Curie
Past Years:
Team 3414: Hackbots, 2013-Current, Mentor
Team 818: Steel Armadillos, 2008-2012, Mentor
Team 93: N.E.W Apple Corps, 2002-2003, Student
Unread 15-01-2010, 19:37
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Re: Linear Actuator
I'm thinking using a compass sensors (reliably) might be out for us.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Linear Actuator nekng Motors 4 09-01-2009 16:59
Pneumatic Actuator Calvin_1631 Pneumatics 1 22-02-2007 11:12
Rotary Actuator Wetzel Pneumatics 4 09-02-2004 21:11
Linear Actuator NoRemorse General Forum 4 17-01-2004 21:02
Damper Actuator??? archiver 2001 1 24-06-2002 01:05
