Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 14-01-2010, 20:27
pbhead pbhead is offline
FTC #1123
pbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nice
The ultimate game breaker bot.
I may have found something that may be too good to be true... but i have not found anything in the rules that would make it illegal.
Immagine a robot... it cant go over the bump... it cant go under. It starts in the middle zone. in autonomous it uses a very basic pnumatic kicker to get those 2 balls just over to its home field... no aiming into the goals... just getting the balls to the right side of the field. very basic.
As soon as tellop starts, it goes in front of its tower, it touches the tower, and then deploys 2 gravity powered guides that physically attach the robot to the sides of the tower, and keep it level. then, using a very basic winch-and hook, it begins climbing. It reaches the top. the top of this robot is shaped in such a manor that the balls that fall off the ball return hit the top of this robot, and the balls are redirected straight back into the goal... a simple servo connected to a bar directs the balls either to the left goal or the right goal.
basicly, a bot that all it does, is that as soon as a goal is scored, it returns the balls straight back into the goal... every one of the 12 balls the other 2 robots place into the goal means that as soon as that ball is placed back on the ball return, 5 seconds later its right back in the goal. if a robot trys to block the goal... this "god bot" simply directs its payload towards the opposite goal. and as an added bonus, you got a minimum of 2 points for hanging.
any thoughts about this?
the only thing that perhaps could be questionable would be the server that redirects the balls to the right goal or left goal... but there are many ways... to use a properly designed lifting mechanism to till the frame one way, and the balls go left, till the frame the other way the ball goes right.
Persons attempting to find a motive in this narrative will be prosecuted;
persons attempting to find a moral in it will be banished;
persons attempting to find a plot in it will be shot.
By Order of the Author -Mark Twain
Unread 14-01-2010, 20:33
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: The ultimate game breaker bot.
How do you intend to climb the tower without entering finale mode? It is only allowed during the final 20 seconds, and I don't think that you could climb the tower while staying inside your frame perimeter.
Go REX!!!
Unread 14-01-2010, 20:35
FTC #1123
if your touching the tower... you can expand to your final config at any time.
rule g30 c. TOWER Contact ROBOT Volume - During a MATCH, ROBOTS in contact with their ALLIANCE TOWER may extend beyond their NORMAL CONFIGURATION volume but may not exceed the FINALE CONFIGURATION maximum volume.
Andrew141WOBOT's Avatar
Andrew141WOBOT Andrew141WOBOT is offline
WOBOT for Life
AKA: Andrew
FRC #0141 (WOBOT)
Andrew141WOBOT is an unknown quantity at this point
you're allowed to leave your frame perimeter if you're touching the tower before the finale.
EDIT: sorry, what pbhead said.
Chris is me's Avatar
AKA: Pinecone
I'm relatively convinced this game does not have a chokehold. It's too big of a design challenge to fit this within the 84 inch cylinder rule while creating surfaces that balls perfectly bounce off of that will repeatably bounce balls into your goals from the middle zone. I think you're overestimating the force the free falling balls have.
Unread 14-01-2010, 20:36
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
This all hings on the GDC's ruling on carrying that many of us have been waiting on. IF the GDC rules that you can "redirect" returned balls, then this plan is genius!
edit: while balls may not always go in the goal after falling, they will be ease pickings for your alliance
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 14-01-2010, 20:43
AKA: Pinecone
I just picked up a ball and dropped it on some angled piece of plastic or whatever from a 3 foot height. It doesn't fly far enough.
Unread 14-01-2010, 20:44
FTC #1123
exactly. just as important as keeping the balls from bouncing into the enemy zone... at a very minimum, it would be very easy to design something passive, and something that doesnt hold on to the balls that just keeps the balls on your side of the field.
Lord Byron's Avatar
Lord Byron Lord Byron is offline
AKA: Tim Sebek
FRC #0538 (Dragon Slayers)
Lord Byron is an unknown quantity at this point
I'm not sure about it being legal but my team had the same idea about redirecting balls when we saw the game. If you can redirect balls off the top of the robot then we're probably going to build our robot for this.
You have a ramen doctor in your secret ramen base!?!
Unread 14-01-2010, 20:47
FTC #1123
fly far enough for what? as soon as the ball passes the front of your bumper, its allready on your third of the field...
Unread 14-01-2010, 20:50
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
That is basically what we're accomplishing right now. Not only will this allow us to redirect but also maintain some control of the game.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 14-01-2010, 20:57
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Assuming that this is legal:
It sounds like an awesome strategy!!! I wish I had thought of it. I have a couple of concerns around actually building this robot. It could be like 190 in 2008. They had an awesome design, and I was amazed that their creativity. The GDC said it was legal, then changed their mind in between GSR and Atlanta. 190 ended up having to run laps with the slowest robot from that year. Also, I am not sure the human players would be fast enough, you could get quite a "bottle neck" for the middle human player with the trident, and incur a bunch of penalties. Otherwise, it sounds AMAZING!!!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 14-01-2010, 21:12
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This would only be able to be done with a PASSIVE mechanism. The balls fall on top of the robot, implying that it falls above the bumper zone.
<G45> Active BALL control - ROBOTS may not control BALL direction with active MECHANISMS above the BUMPER ZONE. Violation: PENALTY.
It would depend on the definition of 'active' as to whether or not you could change the direction the ball went in (i.e. is the mechanism passive if it is in place and not moving when the ball hits it?)
Don't get me wrong, this would be a feat worth seeing in person if it could be pulled off. It is exactly like the space elevator concept. While it's not a chokehold strategy it does leave an additional element in place for the opponents to think about. It is also a good strategy for a robot that can also lift other robots to get two 3-pt suspension bonuses.
GitHub
AKA: Pinecone
Nevermind, I misunderstood.
Regardless, you have to get your robot to hang from the sides, extend a big lexan plate (which people are free to push), and play 3 on 2 on the ground... when your opponents could hoard balls in their zone and score them all in the last minute or so.
Unread 14-01-2010, 21:19
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
As cool as this strategy is I'd be very concerned about it's legality. Especially keeping in mind that that the GDC rules on the "intent" and "spirit" of the rules.
These Rules/Definitions may apply:
<G47> BALL RETURN Interference - ROBOTS may not interfere with BALLS in contact with the BALL RETURN. Violation: Two PENALTIES per affected BALL.
POSSESSION: Controlling the position and movement of a BALL
CARRYING: POSSESSING a BALL that is not in contact with the FIELD
Anyone up for a little game of ultimate frisbee? #2970-Dan Championship Event 17 13-04-2009 10:31
FIRST Game Survivor: Tie-Breaker Justin Montois Games/Trivia 0 19-03-2009 13:20
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
pic: Ultimate 4 Square Field (Vex Game) Alex Cormier Extra Discussion 11 04-07-2007 14:12
The Ultimate Showdown of Ultimate FIRSTiny Billfred Chit-Chat 4 12-04-2006 22:43
