Go to Post I did everything in high school... but only FIRST allowed me to be me. - treffk [more]
Unread 14-01-2010, 22:02
timpanda timpanda is offline
AKA: Danny Timpanaro
FRC #1676 (Pascack Pioneers)
timpanda is an unknown quantity at this point
Question Mechanism to Possess Soccer Balls
Does anyone have a good idea or tips for an effective way to pull in a soccer ball, maintain possession of it by continually holding it, while still being able to drive forwards, reverse, and turn? So far the only idea that comes to mind is a vacuum. Your thoughts? Thanks.
Unread 14-01-2010, 22:08
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: Mechanism to Possess Soccer Balls
Might want to check out the Ball Magnet thread...
Unread 14-01-2010, 23:12
Oh, thanks. I guess my thread was a waste then
Unread 14-01-2010, 23:23
As long as you got the help you were looking for, then it was not a waste at all.
Unread 14-01-2010, 23:34
I watched the ball magnet video and it seems like there's a cylindrical wheel thats spinning in the direction of the robot to pull in the ball and the wood is only there so it does not go into the robot, like the balls would have for last years game. But i think there's a way i could implement this somehow and possibly also use a vacuum to help maintain possession. So this was a big help
Unread 14-01-2010, 23:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Try it with the roller and you might decide you don't need vacuum. But you'll have to try it to know, won't you?
Unread 14-01-2010, 23:41
good point, i'll try to put something together tomorrow to test it out.
Unread 14-01-2010, 23:45
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The limiting factor with our robots is the three inch rule. In our test the ball stayed with the robot going left and going right and even backwards but when the robot moved forward and suddenly stopped the ball popped right out.
Unless we can overcome this limitation the magnet may not work as well as we hope. The next step for us will be trying different sticky materials to coat the roller with . Any good suggestions?
Unread 14-01-2010, 23:50
BENMAN's Avatar
BENMAN BENMAN is offline
FRC #0555
BENMAN is an unknown quantity at this point
Yeah, I was planning on trying out a vacuum suction deal, but after seeing the power of the roller, I think that is all we will need. Looks like tomorrow I'll be trying out the roller on last year's bot wit the soccer balls. Too bad we just pulled the cRio out!
Unread 14-01-2010, 23:51
maybe have something thats gonna have a lot of friction with the ball like sandpaper so that even if you stop it won't move away from the bot, cause the material will be too rough.
Unread 15-01-2010, 00:00
MrForbes's Avatar
AKA: Jim
It will be interesting to see how changing the height of the roller and ingress of the ball affects it. I can see how it could be a problem if we have the ball not in so far, so we'll work on prototyping a more legal version real soon.
Thanks for the input Sam.
btw the roller in ours is ABS pipe covered with spray rubber, which is a product designed for coating tool handles and such.
Unread 15-01-2010, 00:11
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
How about the Sticky Pad? It is a tacky material to help hold cell phones, PDAs, etc. on a dash.
Another idea is the tacky shelf liner. It come in large rolls, so you should be able to attach it to a roller.
Good luck. I look forward to seeing your results.
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 15-01-2010, 00:23
IndySam's Avatar
I was thinking of using spray rubber.
We have lots of experience with drawer liner, but it just falls apart to easily. Not a big problem last year but not real good for the soccer balls. The other thing to worry about is the inflated state and the surface texture of the ball can cause problems.
I'm thinking about a spring loaded roller or something.
Unread 15-01-2010, 03:06
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
We used the same coating on our grippers to handle game pieces in 2007. Tackiness rules!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 15-01-2010, 10:45
RC Dawson's Avatar
RC Dawson RC Dawson is offline
FRC #2972 (RC Dawson)
RC Dawson has a spectacular aura aboutRC Dawson has a spectacular aura aboutRC Dawson has a spectacular aura about
Imagine a large pair of pliers. Take the handles, coated with friction tape or gripper tape, and point them away from you. With the handles opened as wide as they go, the mechanism could satisfy the perimeter rules. Considering the 3 inch penetration rule, when you get to a soccer ball and close the plier-inspired device, the "handles" may in fact extend up to the bumper perimeter, but two seconds may be enough time to grab the ball, reposition, and pass it up field.
Thoughts?
new balls vs. old used up balls agndoggieboi General Forum 31 22-02-2006 14:11
Blocking balls with balls allowed? MrBamboo Rules/Strategy 16 27-01-2006 19:59
Zone Zeal Soccer Balls? Allison K General Forum 3 09-01-2004 19:52
The physics of... soccer balls? Gui Cavalcanti Chit-Chat 9 18-08-2002 16:19
Extremely cheap soccer balls P.J. Baker General Forum 8 10-01-2002 20:48
