Re: Grabbing Output from Robot Sensors
We are using our own code. There are no loops in our teleop, and we haven't used the autonomous yet. We had GetWatchdog().Feed() 's all over the teleop when we were trying to feed the watchdog.
Wait you have no while(true) or while(IsOperatorControl()) loops?
I remember leaving out said while loop and getting the same issue. Last edited by ranc : 15-01-2010 at 03:13. |
Well, we have those loops, but we have no others. We have Feed()'s within those loops, too.
Does the line "GetWatchdog().SetExpiration(0.1);" in the initializers do anything? Can I delete this? |
If there are any Wait() calls in your loop that are greater than 100ms, the the watchtog will also time out. |
Can I SetExpiration at some ridiculously high number to get rid of the watchdog error?
You could use GetWatchdog().SetEnabled(0) for turning it off right before your long wait and then use GetWatchdog().SetEnabled(1) for turning it back on again when you're not initializing whatever you're initializing (i'm assuming your long wait is due to setup of some component)
#7
I'll try that tomorrow. But I haven't a single Wait() in the program. ._.
Can I completely delete the GetWatchdog().SetExpiration() or completely replace it with the .SetEnabled()? Last edited by 1951-44U : 15-01-2010 at 21:48. |
#8
Yes I think you could just use set enabled to turn it off
#9
We tried setting the Watchdog at SetEnabled(0), but still get the same problem.
We set it at 0 in the initializers, in autonomous, in the operator function, and in the operator loop. Setting SetExpiration() at an impossibly high number had no success, either.Last edited by 1951-44U : 16-01-2010 at 12:40. |
#10
New development!
We tried instigating the Watchdog error while watching the serial output, and found something very interesting. We could get output from the serial output (meaning that we got the printf values from the code in the serial output) and the sensors were working fine! Outputting data! But once we turned on the target console on the programming laptop (the programming laptop and the serial output laptop are separate laptops) everything STOPPED. Came to a STANDSTILL. No more output, nothing. The serial output stream seemed to FREEZE. That may be why the dog was barking. But the data we received from the sensors are somewhat strange. The different printf statements mixed and mashed with each other, seeming to overlap. I can't make anything of the data because they overlap so often. Any ideas? |
#11
So when you had just the serial cable plugged in and no target console, was the data reasonable? Is the problem related to having mixed serial output?
#12
I'm not even sure what the data was -- it meshed and overlapped, so the numbers weren't nicely and neatly in line with respective labels.
Example: ______ Turns ______ Position It was like: Turns0003054Position It jumbled all the output. |
| Problem receiving console output from cRIO | Arborama | Programming | 7 | 15-02-2009 03:30 |
| Weird output from ultrasonic and gyro | Yuan Xue Lim | Programming | 4 | 11-02-2009 19:01 |
| live input/output to/from application | MarkH | Programming | 3 | 06-04-2006 01:43 |
| Weird Output from Dashboard Port | Ian W. | Programming | 9 | 06-03-2004 21:33 |
| output from a cell phone? | Ben.V.293 | Electrical | 6 | 24-12-2003 14:52 |
