Go to Post FIRST isnt about getting what you deserve, FIRST is about other people seeing potential in us - and giving us an opportunity that we could never have earned on our own - KenWittlief [more]
Unread 14-01-2010, 15:56
Team2191 Team2191 is offline
FRC #2191 (Fluxcore)
Team2191 is an unknown quantity at this point
Spring loaded Pneumatic piston
ive been looking for a solution to our kicker problem and i looked into clippards products for the solution. they offer a pneumatic piston with a spring insdie which would help with the power and initial speed of the piston. are they allowed?
Unread 14-01-2010, 16:09
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Spring loaded Pneumatic piston
Traditionally we have not been allowed to use them but I have to say I don't see any rule against it this year.
Normally the GDC's round about way to get prevent use of spring return pistons is that you can only use cylinders equivalent to the free order form parts from Bimba which did not include spring return, bore size and stroke. This year <R73 D> only has a maximum bore and stroke.
I'm actually surprised they opened it up this way finally.
Edit: I guarentee that it is asked at least 6 times in the official Q&A anyway because this question is asked every year.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 14-01-2010, 16:27
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
They opened it up last year. Teams did use spring return cylinders. Please don't call them pistons.
The problem with spring return cylinders is you are stuck at the return rate the manufacturer gives you (unless you find someone who will make custom ones.). It's not hard to use a little surgical tubing and make your own spring return where you decide how much spring to use.
Unread 14-01-2010, 18:13
If you are talking gas shocks then those were allowed last year. If you are talking a spring inside a pneumatic piston that is connected to the pneumatics system that is another thing. I do not remember that something like that was allowed last year. From this year's rules
R72
I. For the purposes of the FIRST competition, closed-loop pneumatic (gas) shocks are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
Unread 15-01-2010, 06:55
No not the gas shocks. A pneumatic cylinder with a spring bias forward or backward.
Unread 15-01-2010, 07:42
Do you have a part number and supplier?
Unread 15-01-2010, 07:46
Jared Russell's Avatar
Taking a year (mostly) off
Al:
McMaster sells spring loaded air cylinders. See: http://www.mcmaster.com/#pneumatic-cylinders/=5dun1p
The single acting, spring-loaded cylinders look to me to meet all of the pneumatic rules this year (assuming the bore and stroke are within the limits in the manual, and the cylinder is rated for sufficient pressure).
In my opinion, the main advantage of these cylinders (besides simplicity and one less air connection) is that you are guaranteed that they will return to a known position in the event of an air loss event. In the case of a two-speed, air-powered, dog-shifted transmission, this means that you will always be in gear even if you lose air pressure.
Unread 15-01-2010, 07:56
Thinking.....
This raises some safety issues. Does anyone have other types they are thinking of using for a larger data sample?
Unread 15-01-2010, 08:07
Thinking.....
Al,
Could you elaborate on what safety issues you foresee with spring loaded cylinders of the type I posted? If anything, I could see them being safer than traditional double acting cylinders. (In extension, the total force is reduced by the amount of spring force; in contraction, only the spring is providing force).
Unread 15-01-2010, 09:16
Jared,
Although there are no rules that prevent operation without power, I have never liked robots to move when the system is vented. If these types of cylinders are used, some part of the robot can move when the valve is opened.
A personal wish for safety.
Unread 15-01-2010, 09:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
As of last season, the pneumatic cylinder rules were greatly relaxed—the best robot rule change in a while—and seem to pretty clearly permit all sorts of strange and wonderful cylinders. (Your stroke, diameter and pressure rating are still restricted.)
Since the GDC didn't say (in this year's or last year's rules) that single-action cylinders were distinct from double-action models, I don't think there's any issue with using the manufacturer's definition of a cylinder (which happens to be accepted in industrial practice). I therefore don't think there's any point in asking this one on the Q&A.
Of course, the robot must still satisfy safety rules with regard to energy storage, and the spring in a single-action cylinder will be inspected as such. That shouldn't be a major obstacle, however—lots of teams use springs.
Unread 15-01-2010, 09:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Jared,
It's about the same effect as a robot with a single solenoid valve when the robot turns off.
GitHub
Unread 15-01-2010, 14:06
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
the spring in these cylinders is usually very light. I was looking at a 1.5 inch bore single acting spring return cylinder and the specs said the spring had only about 6 pounds of force. I think the spring is always used to return a single acting cylinder, not to assist its push.
2016 Central Illinois Winner. Curie Division finalist
Unread 15-01-2010, 14:20
Tristan,
I was thinking along the same lines but this does need a little more research.
For those reading this thread, I know stored energy is going to a big concern during inspections. Springs, surgical tubing and pneumatics are all going to be used to direct the ball. Safety in the use of these devices is going to be of prime importance. Be sure you have the ability to release energy before leaving the field as in previous years and follow this...
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R40> for specifications and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe
Unread 15-01-2010, 20:11
if we were to use a spring loaded cylinder we would use the 2" bore with a 4" stroke and a front spring bias. this accomplishes the extra force needed and the extra velocity. the spring described in this system has 30 lbs. force by itself. with the pneumatics added this will be increased more. btw this is offered by clippard
spring loaded launcher sciguy125 Technical Discussion 6 17-01-2006 22:42
Spring return or loaded Cylinders falconmaster Pneumatics 4 13-01-2006 17:16
Spring-loaded claw Anubuss Technical Discussion 8 21-01-2005 15:32
Spring-Loaded Pistons TwoEdge47 Rules/Strategy 2 30-01-2003 21:36
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
