Go to Post Maybe this is something we should put on the backs of our shirts: "beware - this person will stand up and cheer for other teams during FIRST award ceremonies". - Andy Baker [more]
Unread 15-01-2010, 09:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Spring loaded Pneumatic piston
As of last season, the pneumatic cylinder rules were greatly relaxed—the best robot rule change in a while—and seem to pretty clearly permit all sorts of strange and wonderful cylinders. (Your stroke, diameter and pressure rating are still restricted.)
Since the GDC didn't say (in this year's or last year's rules) that single-action cylinders were distinct from double-action models, I don't think there's any issue with using the manufacturer's definition of a cylinder (which happens to be accepted in industrial practice). I therefore don't think there's any point in asking this one on the Q&A.
Of course, the robot must still satisfy safety rules with regard to energy storage, and the spring in a single-action cylinder will be inspected as such. That shouldn't be a major obstacle, however—lots of teams use springs.
Unread 15-01-2010, 14:20
Tristan,
I was thinking along the same lines but this does need a little more research.
For those reading this thread, I know stored energy is going to a big concern during inspections. Springs, surgical tubing and pneumatics are all going to be used to direct the ball. Safety in the use of these devices is going to be of prime importance. Be sure you have the ability to release energy before leaving the field as in previous years and follow this...
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R40> for specifications and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
Teams must be very careful when incorporating springs or other items to store energy on their ROBOT by means of part or material deformation. A ROBOT may be rejected at inspection if, in the judgment of the inspector, such items are unsafe
spring loaded launcher sciguy125 Technical Discussion 6 17-01-2006 22:42
Spring return or loaded Cylinders falconmaster Pneumatics 4 13-01-2006 17:16
Spring-loaded claw Anubuss Technical Discussion 8 21-01-2005 15:32
Spring-Loaded Pistons TwoEdge47 Rules/Strategy 2 30-01-2003 21:36
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
