Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Unread 10-01-2009, 19:17
{td}'s Avatar
{td} {td} is offline
FRC #0167
{td} will become famous soon enough
Obscure Wind River Workbench Problem
So, I just finished (finally) installing everything off of the two disks, and opened up workbench. Following the instructions of team members who had successfully sent programs, i did target > New Connection > Wind River VxWorks...
But on this screen, there is no field for me to enter the ip address where there was for others, using vista or xp. i'm running vista. Here's a picture of what the window looks like:
In other menus, similar problems occured, with various elements of the interface missing or not functioning.
Any ideas? If all else fails, i guess i'll have to re-install, but if any of you knows a fix it would be greatly appreciated!
Unread 10-01-2009, 20:46
Re: Obscure Wind River Workbench Problem
Off-hand I'd recommend reinstalling just Wind River.
Haven't seen that one before though.
Unread 11-01-2009, 22:44
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Are you running 64-bit Vista? I've heard rumors that there are issues with 64-bit Vista, though I'm not quite sure what they are.
Unread 12-01-2009, 05:50
Randy Picolet's Avatar
Randy Picolet Randy Picolet is offline
Caffeine Addic..um..Afficionado
FRC #2159 (RoboPirates)
Randy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud ofRandy Picolet has much to be proud of
Wow.
I have _exactly_ the same symptoms. I removed/re-installed Wind River, but that didn't change anything. Then I completely removed/re-installed both LabView and WindRiver from the CDs again. Still no luck. I gave the same CDs to one of my students with the identical (Vista 64-bit) OS on a brand-new HP laptop (mine is a month old HP laptop...), and his installed/operated correctly the first time.
I also have no idea what is wrong. With the the loss of dialog/menu elements, it seems like perhaps a corrupt/missing class file or DLL? Maybe we missed an update or one failed or something...
Another thing that might be different is our Java/JVM configurations. Eclipse (the IDE underlying the Wind River Workbench) is implemented in Java, so there may be something going on there.
I'll keep poking around on my system. Please post if you make any progress, or if anyone knows what's going on here...
Unread 12-01-2009, 11:05
{td}'s Avatar
FRC #0167
Well, i don't wish this on anyone, but thanks for letting me know i'm not the only one. I went through the same process of you--reinstalling just windriver, then re-installing everything and it still didn't work.
I am indeed running Vista 64bit, so maybe there's something there, but i'm pretty sure one of my fellow programmers is also and his works fine. I could be mistaken. I have about a 3 month old Sony Vaio. I posted the problem on the FIRST forums but haven't yet received an answer.
I updated Java before the last re-install, too, and same problem. If I hear anything, I'll let you know. Keep me posted if you can get it to work!
Unread 10-01-2010, 21:31
pupperish pupperish is offline
FRC #1073
pupperish is an unknown quantity at this point
I'm having the same problem. Did anyone find a solution?
Thanks,
Dan
Unread 11-01-2010, 19:04
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
I have the same problem, I just finished (finally) installing everything off of the two disks, and opened up workbench. Following the instructions. it is not working with VISTA
create a desktop icon. C:\WindRiver\workbench-3.0\wrwb\platform\eclipse\wrwb-x86-win32.exe
nothing there
TEAM 1946-Tamra
Unread 11-01-2010, 19:38
FRC #1073
Hi Yara92,
I'm running Vista x64 on a HP HDX 18 laptop. I just uninstalled everything, turned off antivirus and reinstalled but I still have the same problem. It sounds like Vista x64 isn't supported?
Good luck to us.
Unread 11-01-2010, 21:15
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Same issue here with my comp, I'm running Windows 7 64bit.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 11-01-2010, 21:24
FRC #1073
Welcome to the club wt200999. I noticed there is an install into eclipse option on the workbench help menu. So I downloaded eclipse 3.5.1, 3.4.2, and 3.3.2. I was able to install into eclipse 3.3.2. but still get the same problem. It appears that maybe its just a windriver problem in the menu that sets up the tgtsvr options. Maybe there is a file we can edit to set these options?
Unread 12-01-2010, 11:01
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
The install pamphlet that came with the DVDs this hear says the Windriver runs on XP 32 bit and Vista 32 bit. If they say that it doesn't work on 64bit than I'm inclined to believe them.
Unread 12-01-2010, 20:12
FRC #1073
I was able to get the VxWorks6x_10.xx.xx.2 connection to show up in the Remote Systems window by copying the /WindRiver/.wind/wtxregd.xxx file from a working installation and modifying it. I will test downloading to robot tomorrow.
Unread 13-01-2010, 18:02
yara92's Avatar
AKA: Mohamed
Originally Posted by pupperish View Post
Hi Yara92,
Good luck to us.
I change my laptop to one with XP it is working perfect WindRiver
TEAM 1946-Tamra
Unread 14-01-2010, 19:55
FRC #1073
Vista 64 seems useable now. I was able to download and run code on the robot. Refresh of windows on resize seems a little flaky in workbench. The target console window prints data from the bot OK but if you type commands they come out garbled.
Unread 15-01-2010, 11:09
AKA: Brad
#0190 ( Gompei and the Herd)
I just got word from Wind River. They unfortunately don't support 64 bit editions of Windows for this version of Workbench. So while it might work, they don't expect it to be fully functional.
Feel free to try it, but if you get any unexpected results, you might try the same thing on a computer with a 32 bit version of XP or Vista.
Also, I've been running with 32 bit versions of Windows 7 and it seems to work fine even though the "official word" is that we only support XP and Vista.
Brad Miller
Robotics Resource Center
Wind River Printing from cRio Mr.Macdonald C/C++ 6 12-01-2009 20:42
Wind River header issues dpeterson3 C/C++ 6 11-01-2009 18:17
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
Windriver Workbench Demo Videos neutrino15 Programming 8 27-11-2008 00:06
