Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Unread 14-01-2010, 21:16
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
Wait Exception?
We've been porting some of our code from last year into Java. We tried to execute a wait command, but first we had to wrap it in a try catch statement. It catches the exception with the message:
"current thread (first.team811.game2010.Team811Robot - main (pri=5)]) not owner (null)"
Is there a way we can utilize wait in Java?
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 15-01-2010, 08:35
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Wait Exception?
You didn't post your code, but the likely problem is that in Java you need to lock your object before doing a wait() or notify() on it. The Java wait() will unlock the object, wait until it receives a notify, then relock the object.
You can find some details on this in the Java Tutorial:
http://java.sun.com/docs/books/tutor...guardmeth.html
Unread 15-01-2010, 11:21
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Wait Exception?
Instead of using Wait() you need to use Timer.delay(). The problem with Wait is that is a method on the Object class which is the base for all objects. So using wait doesn't really work.
First, be sure you have this import:
import edu.wpi.first.wpilibj.Timer;
Then, here is an example of using delay:
    public void autonomous() {
        System.out.println("In autonomous");
        for (int i = 0; i < 40; i++) {
            drivetrain.drive(1, 0.0);
            Timer.delay(2); // wait 2 seconds
            drivetrain.drive(-1, 0);
            Timer.delay(2);
        drivetrain.drive(0.0, 0.0); // drive 0% forward, 0% turn (stop)
Brad Miller
Robotics Resource Center
Unread 15-01-2010, 14:13
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
Re: Wait Exception?
Great, thanks!
Exception in Timer.cpp Phazonmutant C/C++ 2 17-02-2009 09:27
Target Exception - Exception in Kernal Task Thxe C/C++ 3 10-02-2009 07:24
error - language-plug-in exception... RedOctober45 Programming 1 16-01-2008 15:54
Joystick Exception? Blair Frank Control System 3 09-02-2007 22:41
Can't wait Rabid Robots OCCRA 0 15-11-2002 22:36
