Thread Tools |
Rating:
Display Modes |
Re: Suction as a method for possessing balls
So we could use FP motors, maybe attached to the 3 inch computer fan to speed it up?
I doubt the computer fan blades are what you want...they are designed to move air gently out of a computer case. The suction fan in a shop vac is quite different, you might see about getting some type of inexpensive vacuum cleaner and taking it apart and seeing if you can adapt the FP motor to it. Consider the RPM that the original motor runs at, though, and see if it's a good match for the FP motor.
No, an axial flow fan is not designed to create much delta P, only flow. You need an radial flow device, like a vacuum impeller. As a rule of thumb when looking at impellers, flow is proportional to the impellers' width, while pressure is proportional to its diameter. So, for max holding power, use a large diameter, narrow impeller, or better yet, a 2-stage impeller system.
I've seen a lot of people say fan for this idea, but an impeller is the fan-like device inside a shop vac. It is designed to work better for this type of application. I'm amazed with the performance people are saying they are getting with a 1" hose. That's only 0.785 square inches. Assuming 1.47 psi, then the holding force is 1.15 pounds. The ball weighs about 1 pound so I'd expect it to barely be able to pick up the ball. A 2" hose would bring the force up to 4.62 pounds and should provide a pretty good grip. Of course a larger grip surface will make that much stronger. In fact is seems very plausable that a suction cup mounted inside the frame could get a good grip. I'd recommend that you don't plan to go over the bump while possessing a ball. I cannot think of a configuration that will work where the ball does not get wedged under the bumpers. Teams always seem to find a way to do what I think is impossible so I'll be watching for it at the regionals. I guess a 6 wheeled robot with an actuated center wheel could do it. Still, I think it's unlikely. Andy |
Choose wisely grasshopper. (my cultural references are way out of date ) |
how would you suggest hooking the fisher price motor to the shop vac impeller?
#7
By the way, we will most likely be gearing up which ever motor we decide to use. We currently are estimating we need something in the neighborhood of 18K RPM. We had to custom build a shaft to replace the one that is part of the AC motor. If direct driving with either motor works, we will post up pics later tonight or tomorrow. If we need to gear up, that will take another day or so to complete. |
#8
Has anyone considered drawing a vacuum using a pneumatic piston? I would think the suction force from the piston would be much greater than from a shop vac. Down side is that if you have a small leak, once the piston reaches the end of it's stroke, you've lost your suction.
Just a thought that I want to tryout myself. -Chip Tucker |
#9
Is anyone actually putting a suction mechanism on their robot? The gray area in the rules makes it seem like a judge could possibly rule it illegal and DQ the robot. And, if the mechanism is too strong and the robot accidentally goes over a bump with the ball, it would be a penalty.
#10
On a suggestion from another teams mentor, I just cannibalized my 18v dewalt vaccum. It took me about 10 minutes to swap the motor in it for a fp. I think we will be using it on the robot.
#11
So far we have determined that using a 1:2 gearing increase and a FP motor on a 6 in diameter impeller from a $20.00 Husky shop vac. will do the trick. We just need to make an adapter plate and assemble the whole thing tomorrow. Heck, we might even put the vac back together when we are finished. That way we will protect the impeller from damage due to field debris and might pick up a coin or two to boot. ![]() |
#12
Which dewalt vac did you use, the DC500 or the DC515?
#13
the dc 515
I just looked at a parts diagram for the 500 and it looks like pretty much the same motor & impeller. Last edited by BJT : 22-01-2010 at 23:59. Reason: more info |
#14
| Orbit Balls - For Sale | Pelicano234 | General Forum | 53 | 02-02-2009 23:47 |
| Alternative Method for calculating “I” term in PID | Holtzman | Programming | 15 | 06-09-2006 13:22 |
| Balls for the game | K.Shaw | General Forum | 1 | 20-01-2004 17:59 |
| What is your favorite method for attaching gears to shafts? | archiver | 2001 | 13 | 24-06-2002 04:00 |
| adhesive for grabbing balls | archiver | 2001 | 1 | 23-06-2002 22:40 |
