Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 15-01-2010, 00:18
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Why swerve is better than Holonomic... HELP
Ok for two years now i have been designing a swerve drive for my team and we as a team finally think it is time for our team to design a omni directional drive train (HOORAH). Before now the team was all for swerve drive. However, some members/mentors changed their minds (due to a vex holonomic a student built) feel that a Holonomic drive is the better way for us to go. Manufacturing and programming of these drive trains are not a problem but because of the simplicity of the Holonomic drivetrain these members/ mentors feel that tradeoffs of the Holonomic drive train will be offset by the time we save in the making and programming of it. As the most experienced student left on the team (and head of design) i feel that we will be better served spending our time on the swerve drive but I am at a disadvantage because i can't really "prototype" the swerve (like we did with the vex holonomic) without buying all the parts and actually building it. Due to the majority of these students/mentors being new to FRC i feel they don't understand how much the reduction in pushing power and other weakness of holonomic drive hurts a Robots performance when compared to a swerve drive. Can anyone who has experience driving a holonomic, playing against a holonomic, or has an opionon on the subject give a testimonial about how swerve is better than Holonomic and the making of a swerve drive is the way our team should go.
Thank you very much for your help
Please note: Yes we have built our swerve drive (partially) before so please no warnings about how if you are designing it now it is to late etc...
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 15-01-2010, 00:41
Re: Why swerve is better than Holonomic... HELP
If you have 2 VEX sets, give 2 groups 1 day for the following challenge: Build a prototype drivetrain. 1 group gets holonomic. 1 group gets swerve. Use standard small green wheels for each drive.
Then, at the end of the day, the head-to-head: pushing, obstacle course, and a sumo match against each other. (Stay in X area. First out, either through pushing or through dodging too much, loses. Best 2 out of 3 or however you want to do it.)
This will give a scale comparison of the two. And yes, it is possible to build a swerve in VEX.
330 did something similar back in 2005 with a mecanum vs. a 6WD "drop". A full-scale kitbot mecanum drive went up against our 4WD 2003 robot in a match situation--and lost.
The match will do several things: It will expose the strengths and weaknesses of both systems. It will give practice with both. If you do it right, you've even got the code for both. And, there will be one of two final results: Either you'll see that you're wrong, or they'll see that swerve is superior.
Edit: We also want to go over the bump. I also feel that the Omni wheels would not have enough traction to be able to go over the bump
Unread 15-01-2010, 00:43
I wonder what a key element in that obstacle course I mentioned earlier might be... Shouldn't be too hard to build one to about 1/3 scale.
Unread 15-01-2010, 09:28
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
I am having a similar problem, only it's the mentors wanting to use a 6WD 2 gearbox design and a handful of students wanting to use holonomic, and the 6WD prototype was built by a mentor. What ever happened to student decisions?
Unread 15-01-2010, 09:39
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Omni wheels still have quite a bit of traction on carpet in their driven direction.
Video of Omni wheel robot up the bump
http://www.chiefdelphi.com/forums/sh...threadid=80226
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 15-01-2010, 09:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Originally Posted by Geek 2.0 View Post
I am having a similar problem, only it's the mentors wanting to use a 6WD 2 gearbox design and a handful of students wanting to use holonomic, and the prototype was built by a mentor. What ever happened to student decisions?
An important thing to consider here, and it speaks volumes about your team's personality, is the following: Is it an adult decision, a student decision, or a team decision?
Hi!
Unread 15-01-2010, 10:23
Chris is me's Avatar
AKA: Pinecone
Build a vex holonomic and a vex 6 wheel and have the Vex 6 wheel play defense on it. Should sell your team pretty quickly on not holonomic.
Have you built, tested, rammed, destroyed, rebuilt, retested a swerve drive? If you have, then great. The only reason (if swerve is desired) you'd want to run holonomic over it is weight savings, simplicity, durability, at the expense of all traction versus defensive robots. If you haven't, your team's got a point in that swerve is deceptively hard.
If you want, send them videos of 1714's 2008 robot, which is holonomic. (Just don't tell them there were programming bugs )
Unread 15-01-2010, 10:27
FRC #0107
Does holonomic really lose all that much traction? What if you use braking on the Jaguars? It seems that it wouldn't be too bad, the only thing hindering you is the hard plastic of the wheels.
Unread 15-01-2010, 11:05
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
First, a picky technical note:
Holonomic is a general term used to describe a system that can be controlled in all of its degrees of freedom [1]. For robot drivetrains, this implies the ability to move in two dimensions. A swerve drive, mecanum drive (jester drive, airtrax), and omnidrive (kiwi drive) are all examples of holonomic drivetrains. They allow movement in both dimensions.
I'm going to assume that my "holonimic drive" you are referring to mecanum drive.
Second, there are major advantages and disadvantages to both swerve drive and mecanum drive. I'm not trying to be rude, but please don't come to this community to enlist support for your side. Take a look around these forums; you'll see that the relative merits of these drivetrains have been discussed numerous times before.
I know you honestly believe that swerve drive is the right way to go. In terms of field capability, you're probably right. But there are a host of other factors, most notably complexity, weight, and manufacturing time, which all affect the decision. And in the end, those factors are actually more important.
There will be great swerve drive robots this year. But there will also be some great mecanum drive robots, and some great omni drive robots. There will even be some great robots that use the kitbot drive train. An awesome drive train might help, but solid ball handling and hanging capability will determine how you do. Don't let yourself think that your drivetrain choice is going to doom your season.
We also want to go over the bump. I also feel that the Omni wheels would not have enough traction to be able to go over the bump.
Feel? The only way to know is to try it. Honestly, I'd be interested to see what happens - 2359 is asking many of the same questions.
Yes. Even if you have wheels with as much traction as any other drive system, you inherently lose between 50% and 71% of your power. Take a look at this paper for an explanation why.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 15-01-2010, 11:20
AKA: Pinecone
If you really want to be clever, just ask your team how many mecanum robots have been on Einstein.
Unread 15-01-2010, 11:26
FRC #0107
I think most people mean 4 omnis, two perpendicular and two parallel (Killough), when they say holonomic.
Also, you would lose the 50%-71% of power, but not traction, so people pushing you shouldn't be too harsh if your wheels are locked. Given you won't have as much power pushing back.
Unread 15-01-2010, 11:31
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
For my presentation on drive trains that I do for our technical conference in Oregon, FIRSTFare, I count up the types of drive trains used by the finalists and winners of the Championship divisions. 2009 was a weird game so setting that aside, 2008 is the last year with useful data. Here are the totals:
14 Six Wheel
2 Six Wheel with omnis
2 Four wheel with omnis
2 Mecanum
2 Crab Drive
1 Four wheel rack and pinion
This was just from the info I could glean from looking at pictures of these robots so I can't claim this to be 100% right but it's close.
Keep in mind that was a very different game than this year so I'm not sure how much weight to put on this. It was also only the second year that Mecanum was widely available from AM and the first year they had 6" Mecanum wheels.
Unread 15-01-2010, 11:49
AKA: Steven Bell
I hesitate to say you lose traction, because your wheels may still have the same grip on the carpet. But even if you lock your wheels, you only have a fraction of your "pushing resistance force". Unless you have a way to physically lock or articulate the rollers as describe in the paper I linked above, up to half of your traction is wasted on rollers that simply spin.
Take a square robot with one omniwheel (rollers perpendicular to the drive direction) on each side. To move forward, two wheels are doing the work, and two wheels are spinning their rollers and contributing nothing. The scenario is identical if we brake our wheels and another robot tries to push us. Two wheels will give us traction on the carpet, but the other two give us nothing.
If the robot moves diagonally, all four wheels move, but all of the rollers spin some. This results in a 1/(sqrt(2)) thing, which is where I get 71% power/traction.
Unread 15-01-2010, 11:50
FRC #0107
Sorry, I really worded that wrong. I made it sound like I'm angry because the mentors won't let me do what I want to do. But that's not it. I just feel that if the mentors don't support it, it won't happen, no matter what. A few students honestly believe holonomic drive will work (that's not to say all though), but the mentors don't want to, and so there's no use in pushing for it because their word is law. You're VERY right, it should be a joint decision.
Thanks for the clarification, that makes sense. I still think the tradeoff is worth it though.
Time precision better than seconds?? Joohoo C/C++ 4 31-01-2009 20:49
Are six wheels better than four? cziggy343 General Forum 36 10-01-2009 23:13
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
