#16
Re: Swerve vs. Mech?
Removing mecanum, swerve, and killough ("holonomic" really isn't specific), you're not left with really any omni-directional drive (those which possess three degrees of freedom). At this point, you need to optimize your ability to turn, but at the same time, to help against defense you need the ability to push. With this in mind, if you can manage a shifting drive train to allow you to have both speed and power available, that could be the best for you (then again, it may not). |
#17
If the team has decided to go with a Mecanum drive train, focus on it. You can tighten the rollers to get more forward traction, yet you will lose strafing torque. Mecanum drive trains are good a pushing if they square up on the object being pushed before pushing or strafing into it (look at 384 in 2008 on Galileo). Evaluate those tradeoffs and stick with the Mecanum decision!
#19
1. Mecanums come with a price penalty we may not be able to afford. 2. They also come with a fairly significant weight penalty. I think there is going to be a strong concentration of pneumatics this year which tend to be heavy. I'm afraid to develop a drive train that uses up my weight budget. We've built the 6WD drop-center before and if it's done right it can turn on a dime AND climb ramps. We will probably need to make a shorter wheelbase because of the steepness of the bumps but I think it can work. We'll be doing the calculations and scale modeling this week. We'd love to get your thoughts. |
#20
Honestly, any drive system can work, the question is really which one is best suited to your goals (and your driver's style). |
#21
Where did you order them from?
#23
AndyMark's site:
http://www.andymark.biz/mecanumwheels.html We got some too; $222 for 4 wheels, plus $60 in hubs if you choose to use their hubs. The difference in weight between these mecanums and other comparable AM traction wheels on a 6WD is only 2lbs total (6WD = 6 wheels * 0.5lbs, Mec. = 4 wheels * 1.25lbs). The real cost/weight savings for 6WD comes with the transmissions, not the wheels; yet there are other factors that 6WD must take into account such as chain, tensioners, and sprockets. Mecanum wheels can pretty much be direct drive and maintain a decent speed/torque balance with the available COTS ratios. Keep that in mind. |
#24
my knowledge of mecanums:
Rack n Roll- we used the 8" andymark mecanums, and our drivetrain/chassis only weighed about 60 pounds. we ended up with the compressor and a fairly heavy lift system as well, our overall weight tht year? 110 lbs. In competition, we didn't really get pushed around at all, and one team (with 4 or 6 WD- i don't remember) actually wanted us penalized for pinning them. what worked out was the manueverability of the mecanums, and we were also able to easily get to and climb other people's ramps. Overdrive- we used the 6" andymark mecanums, our drivetrain was lighter, of course, but the cost that year was the way the 6" mecanums are deisgned. We had the problem of, at championships, the metal holding the wheels together DUG into the carpet, adn kept us from turning at all. that year we also went with some gearboxes which ended up not being able to pull the robot sideways, but that's another story. so, in my experience, mecanums have never really been a problem, as long as you've got your numbers right. this year, we've already gotten some 8" andymark mecanums (about $300 for all 4) and some 12:1 banebots gearboxes. our plan is to drop the mecanums down so that they hang below the chassis about the same distance that the kitbot would. experience with swerve: i have absolutely none. i hear it's difficult to program, etc. my only thoughts are how well it would go up the ramp, but i really don't know about that. |
#25
What maneuver can you do with swerve that you can't with mecanum? A mecanum base can move in any direction with any amount of spin, meaning that it has perfect control of all three degrees of freedom. |
| pic: Too much Mech | joeweber | Extra Discussion | 7 | 12-10-2009 11:48 |
| pic: Mech Warrior 08 | MasterChief 573 | Extra Discussion | 1 | 26-02-2008 09:27 |
| Mech Wheel Programing | whlspacedude | Programming | 5 | 14-01-2008 15:58 |
| paper: Rat Pack and Mech Warriors Match Scouting Sheet, Revised | Lisa Perez | Scouting | 1 | 08-03-2006 09:00 |
| Attn: Mech Designers, Beta Testers Needed! | JVN | General Forum | 18 | 13-12-2005 20:59 |
