Go to Post It really is disconcerting to hear those chains rattling above your head. I think their effect was psychological more than anything else. - Greg Marra [more]
Unread 15-01-2010, 00:58
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
DiscoBots Omni Drive over Bump
DiscoBots testing their omni drive robot on Wednesday, it worked well over the bump. These are 8" AndyMark Omni wheels with standard toughbox configuration.
http://lamar.discobots.org/node/8
More wheels will be added to this drivetrain in the future, but this was a good proof of concept.
Suggestions, Comments ? Let us know what you think.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 15-01-2010, 01:10
racer6 racer6 is offline
AKA: David Rich
FRC #2158 (ausTIN CANs)
Team Role: Driver
racer6 is an unknown quantity at this point
Re: DiscoBots Omni Drive over Bump
looks good
Unread 15-01-2010, 01:22
PerpetualMotion PerpetualMotion is offline
PerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of light
Why omni directional wheels if you can not go in omni directions
Unread 15-01-2010, 02:19
nickd2012 nickd2012 is offline
FRC #2587
nickd2012 is an unknown quantity at this point
"More wheels will be added to this drivetrain in the future"
Unread 15-01-2010, 06:43
LostProphet LostProphet is offline
FRC #1023
LostProphet is an unknown quantity at this point
i think Omni wheels would work if your going with a front wheels drive.
become a fan of Super Nerds!! on Facebook!
http://www.facebook.com/home.php#/pa...5998917?ref=mf
Unread 15-01-2010, 11:28
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Where do you intend to put the other wheels?
Unread 15-01-2010, 12:21
Unless you have a 4 wheel drive robot with two traction wheels and two omni wheels, I think this is a pointless experiment. Whats the point of having 4 omni wheels if you don't move in omni directions. If you are going to add wheels, then its sounds like you're going to have 6WD, which has a much different dynamic for going over bumps then 4WD, so nothing from this experiment can be translated. If you are going to do some sort of holonomic drive, then you are going to be losing traction and again this experiment becomes useless.
Unread 15-01-2010, 12:31
FRC #0107
As far as I understand, you don't LOSE traction with holonomic. However, you DON'T have as much power. In my opinion, this proves that you can make it up with the omnis. With holonomic drive, it'll just be slower.
Unread 15-01-2010, 12:51
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Thanks for posting this lynca. This confirms our K'Nex mockup's tendencies to auto-straighten the rear omni's after the front wheels crest the top. There was one instance where it didn't auto-straighten, but it looks like that was because the whole robot bounced a bit.
I'd recommend adding some weight to the setup, either via a small chield (j/k ), weight room weights, or some other means. It'll be a whole different animal to control when there's mass preventing it from climing and/or assisting it down the other side.
GitHub
Unread 15-01-2010, 14:04
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
I am not a Discobot mentor however, I conjecture that the point of 4 wheel omni drive is to create as much turning ability from a tank steer drive-train as is possible on carpet. With just omniwheels on the front the robot pivots from the mid-point of the rear axle. You will notice in the video that this robot pivots from the center of the drive-train. Not a sweeping or gate turn but rather a point turn.
I too am interested in where, what type, and why they intend to add more wheels are posted by Andrew L.
Andrew S.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 15-01-2010, 15:43
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Andrew S.
You can achieve the same zero turn radius spin with two omni and two traction wheels if the omni/traction wheels are at opposite corners of the robot. So if the front left wheel was an omni, the rear left would be traction, the front right would be traction, and the rear right would be omni.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-01-2010, 01:13
Green2 Green2 is offline
FRC #2338
Green2 is an unknown quantity at this point
I noticed that the robot seems to fishtail at times. Is that due to operator or does the robot have some issues with launching and going straight at the start of motion?
Unread 16-01-2010, 01:48
DTTrobotics1 DTTrobotics1 is offline
Student
AKA: Allan Kuan (2010)
FRC #1346 (DT Trobotics 1346)
Team Role: CAD
DTTrobotics1 has a spectacular aura aboutDTTrobotics1 has a spectacular aura about
I find this experiment that you carried out to be very interesting.
We've been wondering of any way to actually get over that bump for awhile... I don't recall us testing that out yet...
The omni-wheels should also help with the carpet + rubber tire situation.
Unread 16-01-2010, 08:07
GaryVoshol's Avatar
Cogito ergo arbitro
Have you considered adding the bumpers to the bot yet? If those are 8" omnis, it looks to me as if the frame member is 12 or 13 inches off the ground. The bottom of your bumper will be no more than 11". Bottoming out?
And a more general question which should be of interest for all teams - what will keep a ball from rolling more than 3" under the frame in this kind of setup?
(since 2004)
Unread 16-01-2010, 08:18
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
I couldn't view the video but from discussion from our team it would be very diffucult to get over bumps because of the vertical incline. Also watch that if you do put on omni wheels you would be pin pretty easyly(however you spell it) I could be wrong and maybe your robot could get over the bump but watch out for easy pinning.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Over the bump or under the tower quinxorin Rules/Strategy 44 18-01-2010 14:17
omni drive transmissions gorrilla Technical Discussion 21 27-10-2008 21:17
Omni drive Laaba 80 General Forum 12 25-02-2008 01:56
Lego Omni Drive Synergy1848 Robot Showcase 19 03-01-2007 11:51
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
