Go to Post As JFK said we did not do this because it was easy, we did it because it was hard. - Glenn [more]
Unread 15-01-2010, 14:33
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Why swerve is better than Holonomic... HELP
Originally Posted by Creator Mat View Post
Edit: We also want to go over the bump. I also feel that the Omni wheels would not have enough traction to be able to go over the bump
The traction will not likely be the challenge for a holonomic drive base getting over the bump. Unless you have some sort of suspension, it will be virtually impossible to maintain the wheel contact and proper weight distribution to the wheels in order for it to drive properly.
As you go up the bump, one or more wheels will likely be lifted completely off the ground (unless you're using 3-wheel base that's perfectly aligned with the bump), and thus that wheel can no longer contribute to any driving you're doing (which will likely change the direction you're driving, which will likely cause you to no longer climb the bump). Additionally, as your robot is angled, the weight distribution to each wheel will change, also changing the resulting normal force on each wheel (which could also cause a change in direction).
Time precision better than seconds?? Joohoo C/C++ 4 31-01-2009 20:49
Are six wheels better than four? cziggy343 General Forum 36 10-01-2009 23:13
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
