Go to Post Looks to me like they have a tasty robot. - Andy Baker [more]
Unread 15-01-2010, 15:34
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Re: Why swerve is better than Holonomic... HELP
Originally Posted by Lil' Lavery View Post
The traction will not likely be the challenge for a holonomic drive base getting over the bump. Unless you have some sort of suspension, it will be virtually impossible to maintain the wheel contact and proper weight distribution to the wheels in order for it to drive properly.
As you go up the bump, one or more wheels will likely be lifted completely off the ground (unless you're using 3-wheel base that's perfectly aligned with the bump), and thus that wheel can no longer contribute to any driving you're doing (which will likely change the direction you're driving, which will likely cause you to no longer climb the bump). Additionally, as your robot is angled, the weight distribution to each wheel will change, also changing the resulting normal force on each wheel (which could also cause a change in direction).
However, if you're using a holonomic drivetrain (w/ 4 45 degree angled omniwheels) that doesn't have all the wheels in contact, it will autocorrect itself, putting you straight.
Time precision better than seconds?? Joohoo C/C++ 4 31-01-2009 20:49
Are six wheels better than four? cziggy343 General Forum 36 10-01-2009 23:13
Better Than Gears? Aaron Lussier Technical Discussion 7 14-10-2003 12:20
My auto is better than yours.. lol randomperson Programming 25 07-04-2003 12:10
Kennedy better than Long Island?... soap108 Regional Competitions 6 23-03-2002 17:50
