Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Unread 14-01-2010, 22:28
Luigi Panache Luigi Panache is offline
FRC #4829
Luigi Panache is an unknown quantity at this point
Installing Windows 7 on our Driver Netbook
My team has just started to configure our driver station, but we loathe the out-of-date XP interface.
Would it be allowed by this year's FRC rules if I use one of my own Windows 7 keys to install Windows 7 on our team's driver netbook?
Unread 14-01-2010, 22:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Installing Windows 7 on our Driver Netbook
heh...I went to some trouble to get a netbook with XP instead of that silly new 7 interface.
If there is nothing in the rules, you should have your team representative ask on the FIRST Q&A. Suggest you carefully read the ROBOT rules first though
http://usfirst.org/roboticsprograms/...nt.aspx?id=452
Unread 14-01-2010, 22:35
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
<R60> The control system is designed to allow wireless control of the ROBOTS. The Classmate PC, FirstTouch I/O module, cRIO-FRC, speed controllers, relay modules, wireless bridge, batteries, and battery charger shall not be tampered with, modified, or adjusted in any way with the following exceptions:
A. User programmable “dashboard” code in the Classmate PC may be customized. (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.),
B. User programmable code in the cRIO-FRC may be customized.
C. Dip switches on the cRIO-FRC may be set.
D. Speed controllers may be calibrated as described in owner's manuals.
E. The supplied fans attached to the Victor speed controllers may be powered from the Victor power input terminals.
F. The fuse on the Spike relays may be replaced with a 20 Amp Snap-Action circuit breaker.
G. The alligator clips on the battery charger leads may be replaced with Anderson Power Pole connectors (note: this is a recommended modification).
H. Wires, cables, and signal lines may be connected via the standard connection points provided on the devices.
I. Fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT.
J. Labeling may be applied to indicate device purpose, connectivity, functional performance, etc.
K. Brake/Coast jumpers on speed controllers may be changed from their default location.
L. If CAN-bus functionality is used, limit switch jumpers may be removed from a Jaguar speed controller and a custom limit switch circuit may be substituted (so that the cRIO-FRC may read the status of the limit switches).
M. If CAN-bus functionality is used, the Jaguar firmware must be updated as required by FIRST (see Rule <R63-D>).
N. If the FirstTouch I/O module is not used as part of the OPERTOR CONSOLE, the embedded software may be modified. If the First Touch I/O module is used as part of the OPERATOR CONSOLE, the default software image must be used.
To my understanding, no and I think it's pretty clear the driver station is treated as sacred.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 14-01-2010, 22:40
If you use the classmate as a driver station only, you never see the "out-of-date" XP interface.
Unread 15-01-2010, 08:50
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
According to the Control System Manual, Chapter 2: "Getting Started":
2.3.2 Installation Requirements
The installation has been tested on Windows XP operating system. National Instruments and WindRiver have not finished their compatibility testing with Windows Vista or Windows 7, and thus won’t be supporting it for the 2010 FRC season. We don’t know of any reasons why it wouldn’t work, but wanted to let you know that if you use the development software on Windows Vista or Windows 7, you do so at your own risk.
(emphasis mine)
For me, that is reason enough not to install an updated version of Windows. However, I don't recall seeing any specific rules against it.
Unread 15-01-2010, 10:08
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Personally I think that the "out of date" interface should be the absolute least of your worries at this point.
I don't think the risk is worth the result. As they say "don't fix it if it isn't broken".
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 15-01-2010, 10:18
(emphasis mine)
As you have highlighted, it is says development software. IE. Software for writing code. You also must have completely ignored my post.
While I do not know the specifics of how the Classmate's install, I know it is very custom and when you boot into the Driver Station mode, it's scripted very specifically.This may not work in Windows 7. I personally wouldn't take the risk but I'm not your team.
James Tonthat
Unread 15-01-2010, 10:56
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
I'll add my 2 cents as well...
It is not worth the risk to install 7. When you go to a competition and the driver station does not work, my gut tells me you will have a hard time getting FTA support. It has been stressed on a number of occasions to NOT mess with the software on the Classmate except to write code for yoru robot.
Your call.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 15-01-2010, 13:55
ALTrammell818 ALTrammell818 is offline
Strategy Captain and Drive Coach
AKA: Aaron
FRC #0818 (Steel Armadillos)
Team Role: Tactician
ALTrammell818 will become famous soon enoughALTrammell818 will become famous soon enough
Send a message via AIM to ALTrammell818
I wouldn't do it.
Windows 7 32 bit requirements
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
16 GB available hard disk space (32-bit) or 20 GB (64-bit)
DirectX 9 graphics device with WDDM 1.0 or higher driver
Windows XP 32 bit requirements
300 megahertz or higher processor clock speed recommended;
233 MHz minimum required (single or dual processor system)
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Now I don't know about you guys but I'd like to have that extra performance just in case. I however do not know the classmate specs off of the top of my head. Anywho I know it uses and Intel ATOM processor and I would not trust running Windows 7 with an ATOM.
Unread 15-01-2010, 14:15
MrForbes's Avatar
AKA: Jim
Seven works fine on my Acer netbook with a 1.6g Atom and 1g ram, although I do have a big hard drive.
The thing about it being against the rules (apparently) would be enough to dissuade me.
Unread 15-01-2010, 14:18
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
I wouldn't do it.
My personal netbook uses a Atom Processor and Windows 7 works just fine on it.
One thing i would recomend is (Something that's most likely against the rules) to upgrade the RAM. most likely the Classmate PC has 512MB - 1GB of RAM. I would look into upgrading that to 2GB (most netbooks can't go any higher than that) and then go ahead and install 7
just my $0.02
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 15-01-2010, 14:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think I'm not understanding the reasoning for wanting 7 on it? It's not going to run Aero. And are you really going to record TV or watch movies on it, with the tiny hard drive? Yes, 7 is pretty, but for something like this, I don't see any additional features it provides that you actually need.
Unread 15-01-2010, 14:45
MrForbes's Avatar
AKA: Jim
But Windows 7 looks so much better than this!
Unread 15-01-2010, 15:49
acidrain2012's Avatar
acidrain2012 acidrain2012 is offline
FRC #0393 (Full Metal Jackets)
acidrain2012 is an unknown quantity at this point
I can't really see why it would be necessary. As far as I'm concerned, XP is still the best Microsoft OS (granted my experience with Windows 7 is limited). It seems like too big of a risk, especially when the techies at FIRST seem to have done some pretty serious programming to make XP behave the way they want it to. As for LabView not working on Vista or 7, I think that refers more to other team computers or personal computers. I think not changing the operating system on the Classmate is a given.
Three Schools
One Team
Big Dream
Unread 15-01-2010, 15:59
TimDavis TimDavis is offline
FRC #1983
TimDavis has a spectacular aura aboutTimDavis has a spectacular aura aboutTimDavis has a spectacular aura about
I would also caution against updating the the Classmate to Windows 7, or even using for development purposes on a regular basis.
The unit is both underpowered for realistic engineering use, and the utility of a clean OS environment to interface to the cRio system is significant.
I wouldn't want to risk some odd driver or program incompatibility that arose at an awkwaard moment, like at 2AM the night before you ship the robot during a manic debugging session.
Tim
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station 2010 - Netbook? Greg Marra Control System 16 09-07-2009 19:48
Installing FRC software on Windows 7 mwmisner Programming 1 17-06-2009 16:51
Installing windows XP over vista..... John Gutmann Chit-Chat 5 30-10-2007 01:57
Installing MySQL on Windows Dan Zollman Website Design/Showcase 9 06-02-2006 09:40
