Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 15-01-2010, 15:55
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Logitech Dual-Action Gamepad - Axis Problem
Hello Everyone,
We are programming using the Logitech Dual-Action Gamepads.
We've encountered a problem where we can't seem to get proper values from the X and Y axes on the left analog stick.
We've tried printing GetRawAxis for all 6 possible axes, and the left joystick seems to change values on Axes 5 and 6, but gives values of only -1.0, 0 or 1.0 - nothing in between.
Has anyone successfully gotten values from this controller on the left analog stick?
-Mr. Lim...
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 15-01-2010, 16:36
Re: Logitech Dual-Action Gamepad - Axis Problem
Originally Posted by Mr. Lim View Post
Hello Everyone,
-Mr. Lim...
The left analog stick on some gamepads is either a true joystick or the equivalent of a D-pad. Is there a physical switch to change your gamepad from "button" mode to "analog" mode?
Unread 15-01-2010, 17:50
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Are you using the Gamepad class that I posted last year?
(Going strictly from memory since I haven't played with any code yet this year) As Alan said, there's a "Mode" button on the gamepad that either swaps the left stick and the D-pad or changes the left stick to "digital" mode. Try pressing that button a couple times.
Unread 15-01-2010, 18:28
Are you running the latest DS software? What you are describing sounds like a bug that was fixed during the beta.
Unread 15-01-2010, 18:31
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
On the controller, click the little "mode" button that toggles the little red light on/off.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 16-01-2010, 19:28
AKA: Mr. Lim
Thanks guys...
Mode button that toggles the little red light did the trick.
Actually, we ended up restarting the DS, which also toggles power to the game-pad, which in turn reset the "D-Pad analog emulation" mode to off.
Sounds like just about everyone in this thread was right =P.
Thanks again, you can close this thread if you wish!
logitech dual-action gamepad kamocat NI LabVIEW 6 19-01-2010 20:47
New class for Logitech Dual Action Gamepad Mike Soukup C/C++ 8 11-02-2009 20:08
**FIRST EMAIL**/Purchasing 2007 FRC Game Pieces and Yaw Rate Gyro and Dual Axis Accel GNH2000 FIRST E-Mail Blast Archive 7 09-01-2007 18:38
Dual-Axis Accelerometer naor52 Programming 18 27-01-2006 22:06
