Go to Post This thread is so done I can almost smell the burnt. - Chris Fultz [more]
Unread 15-01-2010, 16:49
Iceman1330's Avatar
Iceman1330 Iceman1330 is offline
FRC #2523 (Lab Rats)
Iceman1330 is an unknown quantity at this point
pic: 2010 window motor winch
Unread 15-01-2010, 16:50
zachjo's Avatar
zachjo zachjo is offline
Shake 'N' Bake
FRC #0171 (Cheese Curd Herd formerly Extreme Engineering)
zachjo is a jewel in the roughzachjo is a jewel in the roughzachjo is a jewel in the rough
Re: pic: 2010 window motor winch
How many lbs can it theoretically lift?
unicycling----It's like doing a wheelie forever!
Shake 'N' Bake
Unread 15-01-2010, 18:40
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Nice cad model some specs would be cool our window moder winch never left paper
Unread 15-01-2010, 18:43
Chris is me's Avatar
AKA: Pinecone
I like the use of COTS parts. How are the window motors mating with the Toughbox?
Unread 15-01-2010, 18:50
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
And equally important, how long will it take to lift you?
The window motors are basically 20W motors. This is pretty good but not with respect to the FP (almost 200W) and CIM (just shy of 340W).
Watts matter because speed and torque are just accidents of birth -- you can trade one for the other. Not fast enough, trade away some torque, get more speed. Need more torque, gear it down, give up speed, get some torque.
BUT... POWER is what it is. The peak power of a motor only goes DOWN when you gear up or down, it never gets MORE powerful.
If you are trying to lift a 120lbs motor 3ft in 10 seconds -- that means you need 54 Watts. If you only have 40Watts (the best you can do with 2 window motors at 12V) then you are not going to do that much work (lifting the robot that high) in that amount of time... ...no matter how you gear things...
For what it is worth.
Joe J.
Team #88, TJ2
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
At 12.75 : 1 ratio, you might get 200 ft-lb torque ( ), but only 6.5 rpm.
"It's NOT Just A Robot Thing!"
Unread 15-01-2010, 19:15
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Joe J.
Joe, that is the singularly best expression I've ever heard about how to pick a motor. I never thought about the torque vs. speed being an accident (not really an "accident" because you know what type of rotational inertia etc you'll end up with, but I know exactly what you mean).
I also never thought about looking at a motor from the energy side of things. I've always been more statically oriented, so I looked at torque - can I do it at that speed.... but the energy calculations make it a whole lot easier.
A light bulb just went on. Don't you love it when that happens?
Unread 15-01-2010, 19:29
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Perhaps this winch isn't designed to lift 120 lbs...
Hi!
Unread 16-01-2010, 00:25
Iceman1330's Avatar
@Joe, thanks for the information.
To preface all of this, the winch was designed before I did any gearing calculations, I was just futzing around with solidworks and thought it might be interesting to put up on CD.
The winch was indeed designed as a main robot winch and was designed primarily to fulfill these criteria.
  • Not back-drivable
  • Cheap
  • Minimal amount of machining capability
  • Lifts above platform in 20 seconds
  • Doesn't involve a powered "release" mechanism (such as a latch or pawl)
With regards to speed: It isn't important that it does it quick. The winch is designed to be a bolt-on-bolt-off lifting arm package should the robot require it. All that the team needs from a winch is the design criteria above.
Perhaps you could offer an alternative method? I've racked my brain but everything I can think of is either difficult to implement, costly, or a mixture of the two.
EDIT: So it looks like it could raise itself close to 5 feet in 20 seconds if operating at 40W peak the entire time, correct? (and of course presuming correct gear ratio for that)
@Chris- AM 8mm hubs. The window motor hubs have the 1/2" shaft section ground off (or lathed) such that a hub can attach to them. This is of course presuming that the input gear to the toughbox isn't easily retrofitted to a non 8mm shaft.
Unread 16-01-2010, 15:48
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Beautiful SolidWorks model. Dont forget to count the Mass for your fasteners. But nuts/bolts all in a folder so you can suppress/unsuppress them. In the FeatureManager, right-click Add Folder. Then drag and drop your fasteners into the folder.
You can also enter total mass of the assembly under Tools, Mass Props, Assign Mass Properties. Marie
Unread 17-01-2010, 12:48
frc295 frc295 is offline
FRC #0295
frc295 is an unknown quantity at this point
our team has already prototyped this design minus the gear box and it can lift 120 lbs, but not fast. i would imagine putting a gearbox would a) help it because it would allow for more torque, therefore the motors can spin more freely b) make it too slow to hang in the last 20 seconds. those 2 motors running at 10 watts max a piece made it past the platform in about 10 -15 seconds
Unread 17-01-2010, 12:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're looking into making a dual window motor winch to power a kicker, and using the 5th CIM to lift the robot. Window motors are not very powerful for lifting a robot, but they are powerful enough to pull 50-100 lbs a short distance in a couple seconds to shoot a ball.
Unread 17-01-2010, 13:19
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
wouldn't how fast it lifts the robot depend on the size of the spool?
So if you had a 4inch diameter spool then it would pull in roughly 12" of cable each revolution, so if it's spinning at say, 60rpm, then it would pull in around 720" per minute or 12" per second?
Should work the lift the robot 72" in 6 seconds?..
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 17-01-2010, 13:53
MrForbes's Avatar
AKA: Jim
The diameter of the spool affects the time it takes to take in a certain amount of cable, but it inversely affects how much force you apply to the cable. So if you use a larger spool, it winds faster, with less pulling force (assuming the same motor and gear ratio driving the spool).
Unread 17-01-2010, 14:11
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Easy fix use two sim motors
Every day is a new adventure!!!
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
pic: Team 1293's Window Motor Drivetrain 2 Billfred Robot Showcase 18 03-02-2005 23:33
pic: Team 1293's Window Motor Drivetrain 3 Billfred Robot Showcase 0 03-02-2005 21:20
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
