Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 15-01-2010, 20:16
Jonathan W.'s Avatar
Jonathan W. Jonathan W. is offline
FRC #1351
Jonathan W. has a spectacular aura aboutJonathan W. has a spectacular aura aboutJonathan W. has a spectacular aura about
Cam trigger
Hi Teams,
For a kicker design, we are looking at using a large L bracket attached to a spring posed to pull it clockwise in some manner. A motor driven cam would turn clockwise against the bracket and act as the trigger. The rough CAD (please don't bash the CAD)
Opinions or advice? Have any teams implemented this type of design before? We specifically need input on a safety release method. (i.e. releasing a cocked kicker with our power cut)
Unread 15-01-2010, 21:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Cam trigger
I came up with a similar design, but the cam's axis of rotation is vertical, not horizontal.
We want to make our kicker have adjustable range, and it looks easier to accomplish that with a winch.
Unread 15-01-2010, 22:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Cam trigger
Well you likely won't be able to rotate the cam safely with the power off. Why don't you put your springs/elastics on something you can release to slacken them? If you attach them to some kind of sliding/swiveling plate then you can lock the plate in place for competition with yet another cam, and let up the pressure on the plate to relieve tension on the springs.
Unread 18-01-2010, 16:16
FRC #1351
Re: Cam trigger
Thanks! Hopefully we will keep all our limbs this season.
Unread 18-01-2010, 16:23
FRC #1351
Re: Cam trigger
We are doing some preliminary calculations on the torque required to turn this cam. We picked out some springs (Lee Spring part # 177P 03 S), and did a feasibility calculation. We ended up with 32.17 N*m required to turn the cam a final increment as the spring is at nearly full extension. (80 lbs of force). See attached work. We assumed that the spring would be attached directly to the point where the Cam contacts the kicker arm, and that there is no friction.
Is this 32.17 N*m answer reasonable??? (lifting a bit more than half a robot)
Thanks
Trigger buttons chinckley Programming 6 16-02-2009 14:33
Programmer a motor with a trigger programmr Programming 9 14-02-2009 23:16
Joystick Trigger Programming dnrobotics11 C/C++ 7 09-02-2009 19:27
making a trigger a toggle team877 Programming 3 02-02-2007 13:26
Ball Chute Trigger pludodog Technical Discussion 1 12-01-2004 10:26
