Go to Post Cheap is always a good thing, unless you are building a robot. - Francis-134 [more]
Unread 15-01-2010, 20:33
CRASH999 CRASH999 is offline
We try!
FRC #0999
CRASH999 is an unknown quantity at this point
Getting Camera Footage on the Classmate
We, CRASH 999, have used LabView since the beginning of last season and will be using it this year. We had the camera mounted last year and did get it to work but didnt have any use for it. This year we plan on using it more. We are able to get the video feed to play on the LabView front panel but are unable to get it to display on the Classmate. We have the robot, Classmate, and laptop all networked together using hardwires and a router. We can get all kinds of data to display on the Classmate like the joystick but just cant get the camera to display on the Classmate. We are using the default coding. I dont know if maybe the default coding doesnt support it, if not then can someone please tell us how to get it to display on the Classmate? Any help would be great. Also if you are experiencing the same troubles maybe we can be hopeless together.
Unread 15-01-2010, 21:20
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Getting Camera Footage on the Classmate
Do you have any video feed at all? IE. can you view the feed in your browser at all?
In order to view the camera in the dashboard you must connect the camera to the Crio and the rest of the kit (I think).
If you wish to simply test the camera and view a live feed you need to follow the instructions in section 2.12 in the 2010 robot controls document (here)
In short you need to change your ip address to 192.168.0.X (x can be anything but 1 or 90, I used 99)
You then need go to 192.168.0.90 in your web browser and set up or put in the root password (default is pass)
You should then see a live feed from the camera. After this you should be able to change the cameras IP address from 192.168.0.90 to what ever your classmates IP is. i.e. The classmates IP is 10.XX.YY.5 so you would change the camera's IP to 10.XX.YY.ZZ (Make sure ZZ is not the same as the Classmate, I used 9) After you have plugged the camera into the Classmate you should then be able to view the live feed by going to 10.XX.YY.ZZ on the classmate.
Make sure you have all cables are plugged in and the camera's LEDs are green.
Hope that helps,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 16-01-2010, 11:48
TheBigCheese TheBigCheese is offline
FRC #0619
TheBigCheese is an unknown quantity at this point
We're having the same problem here, it works fine when connected to the computer and through the NI Vision Assistant, but when we try to get a feed using the Camera demo code with Java, nothing comes up on the Laptop.
Unread 16-01-2010, 21:19
The updated dashboard on the Classmate includes a gyro-sensed heading indicator. If you don't have that, and your dashboard video window shows the camera communication error message, you haven't successfully updated the Classmate software. Run the updater twice, uninstalling the first time and reinstalling the second time.
Unread 17-01-2010, 00:00
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Also make sure that your camera is configured correctly according to the guidelines set by FIRST. We found today that our camera needed to be hooked up to the computer and that we needed to run the Camera Configuration Setup tool (or something like that, it's found under Start->National Instruments->LabVIEW 8.6).
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 20-01-2010, 10:30
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Another important point is that the camera needs to have a specific combination of username and password. The default username "root is OK, but you then need to change the password to "admin". The cRio will not be able to access the camera if it isn't correct. You may also want to view this thread: http://www.chiefdelphi.com/forums/sh...d.php?p=902975. There have been issues with the installation of the driver station. You may have to install/uninstall/and re-install the drivers station with the updated installer.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 23-01-2010, 12:29
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
My team is using Java and trying to get the camera working on the driver station. We have v19 on the cRIO and all the netbeans plugins are updated. Also, the camera has the FRC account and the root account on it at the right IP address and is plugged into port two via ethernet.
that said, there is something wrong with the code we are using:
AxisCamera.getInstance().writeCompression(0);
AxisCamera.getInstance().writeResolution(AxisCamer a.ResolutionT.k320x240);
AxisCamera.getInstance().writeBrightness(10);
it keeps erroring out when we deploy with that code in our program, but not if we comment that out. is this the right code?
Java Camera Video on ClassMate Thomas4019 Java 8 16-01-2010 00:18
Getting the Image from the Camera Using Windriver (C++) computerish C/C++ 0 17-01-2009 16:03
Getting the Camera out of Idle Eclipse Programming 2 13-02-2007 04:06
Getting the camera to work in autonomous dpick1055 Programming 8 10-02-2007 20:57
Getting the square footage to build a full field Ethulin General Forum 15 09-02-2006 11:09
