Re: Official Team Update #2! 1/15/2010
I think regardless of how they worded it, the intent is very clearly that the GDC does NOT want to see robots designed to deflect balls in a specific manner, or guiding them in any manner above your bumpers other than preventing a ball getting stuck on top.
|\ | \ | \ | \ | \ | \ ________ Last edited by Racer26 : 01-17-2010 at 02:34 AM. |
<G45> always restricted this behavior using an active mechanism, which has now had its definition clarified. <R19-B> as modified requires that balls only extend a maximum of 3" inside of any (passive) MECHANISM or feature above the BUMPER ZONE that directs the balls in a controlled manner. In my opinion (which of course doesn't mean anything), the ball does not extend inside the sloped feature you've shown at all so that would be legal. A little bit more clarification though Q&A is probably necessary for this rule. |
<G45> Blue Box MECHANISMS are considered "active" if they are in motion relative to the ROBOT while in contact with the BALL. Resetting or moving MECHANISMS while not in contact with a BALL is permitted as the MECHANISMS are not considered "active." As far as <R19-2> - let's be real here. How does a ball "extend 3" inside" a flat PLANE? It doesn't. A flat deflector above the bumper zone is legal, as long as it is not in motion relative to the robot any time it is in contact with a ball. I believe the GDC is referring specifically to chutes, channels, funnels, diverters and other above-bumper zone structures designed to more precisely control the direction of ball movement. A diverter that can be pointed toward one goal or the other *would* be legal, as long as the diverter walls envelop 3" of the ball's height or less. Such designs are allowed, but the 3" limitation is in place to prevent *too* much control. Send a ball down a high-walled waterslide versus a typical playground slide with short rails. Which one keeps the ball down the intended path better? The waterslide. Which one is legal for competition use? The playground slide. Last edited by Travis Hoffman : 01-17-2010 at 03:54 AM. |
My feeling is that if you can demonstrate that it fits around other robot geometry and is simply to keep the balls from getting stuck on top, they will accept it. A random wedge with no other visible purpose or necessity will probably invite serious scrutiny, and probably deemed illegal if it is used as such in any match. This is simply how I have interpreted the update, but by no means am I a certified robot inspector or a member of the GDC, so my opinion is only that. |
#7
I disagree with you. Look carefully at G45 in update 2: Quote:
#8
| [OCCRA]: Official Update #1 | Mike Martus | OCCRA | 0 | 09-12-2007 07:12 PM |
| Official Unofficial Robotics Film Contest Update. | BuddyB309 | General Forum | 0 | 02-11-2006 08:33 PM |
| Official FIRST Team Update | Jake Lewis | Rules/Strategy | 1 | 01-13-2004 08:03 PM |
| Official update #1 - 9/13 - Mike Martus | Mike Martus | OCCRA | 0 | 09-13-2003 09:48 PM |
| Official - Materials update. | Mike Martus | OCCRA | 0 | 09-26-2001 05:15 AM |
