Go to Post Learn to respect the opinions of others, even if they are the complete opposite of yours. - Hallry [more]
Unread 15-01-2010, 23:03
Chris is me's Avatar
AKA: Pinecone
Re: Mecanum/sticky hybrid
Originally Posted by Sam2197 View Post
is it possible to run two mecanum wheels on the front of the robot and two sticky wheels in the back. if so would we have a ton of worry about going over the bumps from my thoughts it sounds good because it lets us have a really long base and still be able to turn without having a six or 8 wheel drive or having a narrow base. just wonderin if this is a innovative way of using a mix of two worlds and be succesful or just doomed for failure
Two omni (not mecanum), two traction wheels is a fairly common way to reduce turning scrub, at the expense of one side of your drivetrain being fairly easy to spin.
Unread 15-01-2010, 23:05
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
thats why i was thinkin the mecanum. i have heard of the omni's being used. but i was thinking this would provide a little more stability from getting bumped or just driving make it more stable.
Unread 16-01-2010, 03:17
EricH EricH is online now
It's possible that it would work. If you did it right, you could also get the same effect from cutting 45* grooves into an AM Lunacy wheel tread.
Some time ago, while I was still on a team, my dad and I did a VEX-scale prototype of a rather slick mecanum-pattern drive. There were no rollers involved. Not only did it turn well, it acted like a mecanum in terms of sliding. We never did go full-scale, though, so I don't know if it would work in FRC.
The original intent? Make turning easier. It did have that effect. You don't need mecanum code, either, IIRC. Just the right roller orientation.
If you've got any mecanum wheels laying around, do a quick test with the KOP sticky wheels and the mecanums in a KOP frame, standard drive code, all that sort of thing. That's the only way to tell for sure.
Unread 16-01-2010, 13:17
Sam2197's Avatar
Team Role: Driver
yea we'll give it a shot on monday. i dont htink it would require direct drive would it. im not exactly sure at the moment.
Unread 16-01-2010, 13:18
I don't think so. A standard 4WD setup should work well enough.
Unread 16-01-2010, 13:26
Sam2197's Avatar
Team Role: Driver
alright thanks for the help.
A Sticky Situation..... C7First General Forum 29 17-08-2007 14:17
sticky hands to retrieve balls? Jeff Sharpe Rules/Strategy 6 31-03-2004 21:31
