Go to Post There is a problem getting girls interested in STEM. Swift, immediate action is required. Continuing to stay the course leads to disaster. - Madison [more]
Unread 15-01-2010, 23:35
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
non-pneumatic "kicking" mechanism
what teams are attempting a "kicker" that is not a pneumatic in any way shape or form?
what will provide the power and how will it "reset" have you found it to be more powerful that pneumatics?
it wasn't like that when we shipped it
Unread 15-01-2010, 23:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: non-pneumatic "kicking" mechanism
I can't say that the team has committed to using this, but one non-pneumatic mechanism that came out of the brainstorming was a shooter mechanism similar to those used in Aim High. Think of a wheel, maybe 6" in diameter, spinning fast. When it comes in contact high on the ball, it puts a heavy top spin on the ball, which then rolls away fast. Get the angles right, and maybe make that wheel move up or down a little and you can kick it into the air, or roll it fast enough that the Bump does the airborne part for you...
Unread 16-01-2010, 00:32
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
Actually, my team is trying something similar to that. We have a spinning roller attached to an arm which is pulled forward by surgical tubing. We been getting good results so far, hitting the ball at least twenty feet and over a bump. However when we just had the straight spinning roller to the ball, the ball went fast and far, sure, but it hit the bump and bounced off.
Unread 16-01-2010, 01:36
Happy Birthday! Maxzillian Maxzillian is offline
AKA: Eric H.
FRC #0935 (RaileRobotics)
Maxzillian is on a distinguished road
Send a message via AIM to Maxzillian
So far we've been looking at a sort of slide hammer design that relies on the surgical tubing. Initial calculations are very promising, but this thing will certainly need finger guards! The thought was to make a device with only a 12" stroke, but it would require 300 lbs of spring force!
Some revisions are in order.
Team 935 RaileRobotics Alumni: 2001-2004
Team 935 RaileRobotics Mentor: 2009-Present
Unread 31-01-2010, 20:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
1350 is planning on using a *censored* to *censored* a *censored*-*censored* kicker along a *censored* that will be *censored* with a Pneumatic 'device'. this is the only pneumatic 'device' planned for the kicker system.
I think that could be considered non-pneumatic
Edit:
hint:
AAAAABCCCCDDDDEEEEEGHIIIKKLLLLLNNOOPPPRRRSSSUW
Unread 31-01-2010, 20:34
Chris is me's Avatar
AKA: Pinecone
Our kicker will have a mode that doesn't use pneumatics, but we will extensively be using pneumatic actuation in every part of the robot except the drivetrain. Shifters cost a lot of money.
Unread 31-01-2010, 20:38
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
A simple swing arm attached to a CIM does wonders. Not to mention that the strength is variable, because you can change the speed that the hammer swings at. Think croquet.
Go REX!!!
Unread 31-01-2010, 22:30
DonRotolo's Avatar
Back to humble
FRC #0832
The spinning wheel is out (good thing, too). Now we have a more conventional 'leg' powered by latex tubing, reset with pneumatics.
Unread 31-01-2010, 22:59
Mind posting a video ?
Unread 31-01-2010, 23:34
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
We are doing something close to that except the CIM spins a wheel that is not directly connected to the kicker. The kicker is pretty much a wheel with a foot sticking off of it. when we put the CIM wheel against the kicker wheel the kicker spins forward and kicks the ball. The wheel is then retracted by a spring.
Unread 31-01-2010, 23:49
Simpsonator Simpsonator is offline
FRC #0604 (Quixilver)
Simpsonator is an unknown quantity at this point
Don't wanna give too much away, but we will be using a sort of bell crank mounted to a large wheel to retract our kicker, and surgical tubing to snap forward
Unread 01-02-2010, 00:03
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
we are using surgical tubing w/ a window motor and clutch. however, the clutch part is a mess. that is all i will say...
Unread 01-02-2010, 00:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
heh....it's not an easy thing to design and build.
I'll let you know if we ever get ours working
Unread 01-02-2010, 00:14
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
We will be using a crossbow type linear device powered by surgical tubing. The front carriage with the kicker will be pulled back by a second carriage on a lead screw. Releasing a latch will separate the carriages and the kicker will fire.
Unread 01-02-2010, 03:24
run the trap!!!
Team Role: Human Player
Ours does anywhere from 2' to 35'
We used the T-box and a single aluminum tube with an L-bracket on the end. Took about 20 min to build
-Philip J. Fry
Extra "non-vex" sensors MRClark VEX 2 22-01-2008 16:46
Controlling a "fork lift" type mechanism. Brad Voracek Programming 4 18-01-2007 22:53
FIRST "Final 4": Ready for live TV (non-NASA TV)? David Brinza General Forum 15 10-05-2006 00:02
Non-Engineering Mentor "Meet and Greet" in Atlanta! KathieK Championship Event 0 27-03-2005 09:43
"Ball Return" mechanism... what is it? Randy_Ai Rules/Strategy 1 09-01-2002 16:12
