Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 15-01-2010, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Spring loaded Pneumatic piston
If these types of cylinders are used, some part of the robot can move when the valve is opened.
No different than if I tied some latex surgical tubing to the end of the cylinder rod, which would retract it if air pressure was released.
However, your point about safety is an excellent one: A gentle movement to a safe position with air release is one thing, but I can imagine some violent stuff that can happen when air is released (or lost) which could be quite dangerous and must be avoided.
Unread 15-01-2010, 23:33
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We are using a 2x4 piston (cylinder) with added springs to move a hamer type kicker. It would not kick fast until we removed the cylinder. We found that the exhause valve was not allowing the air to escape fast enough. Would a different valve work ar maybe a larger hose and valve? We were thinking of doubling up on the ehaust valve and hose to allow more air flow.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 15-01-2010, 23:51
DonRotolo's Avatar
Back to humble
FRC #0832
It may be helpful to peruse the rules.
<R72> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2010 FRC ROBOTS include the following items. All included items must be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi, and used in
their original, unaltered condition (except as required for assembly with other components).
<snip>
C. Solenoid valves. All such valves must have a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
<snip>
E. Additional 0.160” inch inside diameter pneumatic tubing functionally equivalent to that provided in the KOP, with the pressure rating clearly factory-printed on the exterior of the tubing (note: alternate tubing colors are acceptable).
spring loaded launcher sciguy125 Technical Discussion 6 17-01-2006 22:42
Spring return or loaded Cylinders falconmaster Pneumatics 4 13-01-2006 17:16
Spring-loaded claw Anubuss Technical Discussion 8 21-01-2005 15:32
Spring-Loaded Pistons TwoEdge47 Rules/Strategy 2 30-01-2003 21:36
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
