Go to Post Just wondering what types of food you have been living off of while working on your robot? Our team has had pizza almost 3-4 times a week or more. Just wondering. SGS DRAGONS - sgsdragons [more]
Unread 15-01-2010, 23:56
scottbot95 scottbot95 is offline
FRC #1388 (Eagle Robotics)
scottbot95 is an unknown quantity at this point
NetBeans not talking to the cRio
I tried to deploy a program to the cRio by clicking the run button and it always got hug up while it was "Waiting for the OTA server to reply".
Has any one had this problem before? And if so will they tell me how to fix it?
Unread 16-01-2010, 11:35
fallenangel529 fallenangel529 is offline
FRC #2791
fallenangel529 is an unknown quantity at this point
Re: NetBeans not talking to the cRio
I have the same issue and were getting "No route to host" is that what your getting.
Unread 16-01-2010, 12:04
no, after netbeans did some upgrading on the crio it sat there waiting for the "OTA server" for half an hour then i gave up on it.
Unread 16-01-2010, 13:07
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
It sounds like you are running the software from the DVD or a beta version.
You need to update the FRC plugins as described at:
http://first.wpi.edu/FRC/frcjava.html
You may also need the "mandatory LabVIEW update".
Unread 16-01-2010, 16:20
Ya, I looked into that and made sure that all the updates were installed ,but it was the pre-installed software that the classmate came with, if that matters
Unread 16-01-2010, 18:28
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
The software that came with the Classmate is not the most recent - I had the same problem, but using the update site fixed it.
If you haven't already, go to Tools>Plugins>Settings
Click Add.
Use this URL: http://first.wpi.edu/FRC/java/netbea...te/updates.xml
and name it anything you want.
Now Netbeans should update automatically.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 16-01-2010, 18:52
I am fairly sure i did that already but i make sure and check on monday when i have access to it again.
Unread 16-01-2010, 19:30
a kenny03 a kenny03 is offline
Robotics for life(stupid classmate)
AKA: PICKELL!!!
FRC #0219 (Team Impact)
a kenny03 is an unknown quantity at this point
Send a message via AIM to a kenny03
Click Add.
there is a second plugin update you need for netbeans as well as that one. look on the forums.
Unread 16-01-2010, 20:50
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Also, don't forget to perform the LabVIEW update on whichever machine you are using to format the cRIO, and that the cRIO has the latest v19 firmware.
Unread 16-01-2010, 20:58
We are using the classmate to image the crio and it used the v19 update so that shouldn't be a problem
Unread 18-01-2010, 20:47
It still wont work and i did every thing
if any one else has something to comment about please reply.
Unread 18-01-2010, 21:27
derekwhite's Avatar
Hi,
Please post the Run output so we can get to the bottom if this. Thanks.
Unread 22-01-2010, 00:39
Sorry it took so long but my team was really focusing on labview. Anyways heres the output:
init:
init:
No to.jar.file specified.
Using "suite\RobotTemplate_1.0.0.jar"
Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build
Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\j2meclasses
clean:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build
Compiling 1 source file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\build
compile:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\j2meclasses
preverify:
Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Building jar: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Romizer processed 71 classes and generated these files:
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.sym
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.metadata
  C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.api
Expanding: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar into C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\suite
Deleting: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\RobotTemplate\image.suite.api
Connecting FTP @10.13.88.2
Remote VM does not match, upgrading
Remote bootstrap suite does not match, upgrading
Remote bootstrap suite matches local, no upgrade needed
upgrade:
Sending local file image.suite
Verified
flashapp:
deploy:
init:
Waiting to connect to OTA command server of 10.13.88.2:8001
After that last line it just sat there for half and hour before i just cancled the run
Unread 22-01-2010, 09:25
derekwhite's Avatar
OK, you are running an older version of the Java SDK (netbeans modules).
Set your FRC plugs-in update site to
Check the page at http://first.wpi.edu/FRC/frcjava.html for updated docs and more details.
Unread 29-01-2010, 20:00
I just tried that several times, and thought maybe i should reinstall the plugins and i still didn't work.
P.S. My team has given up on Java and I was bearly able to squeeze in these tests before our meetings. Sorry if I don't reply for a while
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Laptop is not finding the cRIO properly? Studentish Electrical 4 07-05-2009 12:03
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Heres a big problem that I think Discreet does not know what they are talking about. wes16zeus 3D Animation and Competition 9 09-01-2002 23:31
