Go to Post FIRST is supposed to be a learning experience. Learn first, win awards later. - evulish [more]
Unread 16-01-2010, 10:13
Nathan2974 Nathan2974 is offline
Nathan Weiss
FRC #2974 (Team WALT)
Team Role: Electrical
Nathan2974 has a little shameless behaviour in the past
Gearbox Output Shaft Defect
Hi, I am from team 2974; we are a second year team.
In assembling our gearboxes, we stumbled across an issue pertaining to the gear shafts. One of the shafts had an input 1mm too wide in diameter but had a proper output size. On the other hand, the other shaft had the proper input diameter but the output diameter was off by approximately .05 mm.
If anyone else encounters this error, let us know. We would like the community to be aware that faulty parts are afoot!
-Nathan
Unread 16-01-2010, 10:21
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Gearbox Output Shaft Defect
Our gearboxes were fine.
You should call AndyMark.biz and handle the issue through them.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 16-01-2010, 10:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Thanks for the reminder that teams who plan to use the kit transmission should at least test assemble it soon, so any problems can be fixed right away. AndyMark is very good about sending replacement parts right away, but you have to let them know you have a problem.
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
