Go to Post I'm sure I'm not the only one that feels like a blind man in a room full of sharp objects when it comes to programing. - Protronie [more]
Unread 14-01-2010, 05:28
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Cypress board
Hi all,
I've been trying to update the firmware on the Cypress board(I don't know what it is called ) using the Classmate given to us. Classmate my team has did not recognize the board at all. I tried doing it several times but I couldn't get it to sync with the Classmate. So, I just used my own personal laptop to update the firmware on Cypress and worked. Even with the updated firmware, Classmate did not pick up the Cypress board even on the dashboard.vi.
What could be the reason why Classmate is not recognizing the board? Is there a fix to this problem?
side note: USB ports are working fine
Unread 14-01-2010, 05:36
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Cypress board
Similar problem reported by others here
The fix reported in that thread was to uninstall and reinstall Cypress software on the Classmate.
Unread 14-01-2010, 05:41
bls0620's Avatar
Re: Cypress board
Thank you for such fast reply. There was a reason why I couldn't find anything about Cypress IO board under this category
Unread 16-01-2010, 12:10
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Re: Cypress board
if u still have trouble after reinstalling the cypres software with disk, reinstall the FIRST componets of the cypress software. run the DS update setup.exe. when it pops up with the componets to install, click where the cypress componets are and place an x over them so that it uninstalls the componets. then continue. afterwards, rerun the DS update and select to install the cypress(so there will be a check over it). This helped us, because after originally reinstalling the cypress software, our driver station still couldnt connect to the board, only the PSoc programmer could connect.
Unread 17-01-2010, 23:22
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Re: Cypress board
I would probably try making a DLL file in C and including it on the LabView code. Make the DLL file so that it includes conversion and detection systems so that it can pick up the board and be able to understand it's output.
Cypress FirstTouch hex file? chronon FRC Control System 6 08-02-2010 12:29
Cypress Board Configuration Geek 2.0 FRC Control System 12 17-01-2010 04:23
Cypress IO board connect SteveD FRC Control System 12 16-01-2010 16:46
Cypress Programmable System-On-Chip Solution? 1jbinder Electrical 5 12-01-2010 22:13
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
